My vodafone dongle appears to have stopped working, the green or blue light comes on, the computer says the dongle is working, but I can't get on line! (I have great signal here)
Reboot the computer.
If that doesn't work. Turn the computer off. Remove the dongle. Turn on the computer. Insert the dongle. Wait until the computer finds and install it.
<p>Bluetooth wireless technology allows many devices to connect
wirelessly to computers, keyboards, mice, speakers and even other computers.
Most desktop computers come with Bluetooth pre-installed adapters, allowing
many to purchase and install an external Bluetooth dongle adapter. These
dongles are usually connected to an available USB port and automatically
installs without much fuss, but there is the possibility of going wrong,
because usually when people and computers interact. Fortunately, hiccups are
usually quite easy to solve. <br />
<p><br />
<p>1. Unplug the dongle on the computer using the "Wizard
Safely Remove Hardware". Look for an icon in the Windows taskbar that
looks like a USB connector with a green circle and check mark next to it. Wait
a few minutes, and then reinsert it. This will cause the drivers are loaded on
your computer and your problem. <br />
<p><br />
<p>2. Restart the computer; make sure the dongle is working
properly. Some drivers need to restart your computer before working properly. <br />
<p><br />
<p>3. Download and install the latest drivers for your
Bluetooth dongle. If you are unsure of where to get it, Windows can do it for
you. Open "Control Panel" menu "Start," click
"Hardware and Sound" and then "Device Manager". Expand the
Bluetooth Radios section "from the list that appears, right click on the
Bluetooth adapter, and select" Update Driver ". Select" Search
automatically for updated driver software. " <br />
<p><br />
<p>
<p>4. Then remove, reinstall the Bluetooth dongle. Right-click
on the Bluetooth dongle "Bluetooth Radios" from the "Device
Manager" and select "Uninstall." Remove the dongle from your
computer, restart the computer. Connect the dongle back and reinstall drivers
for Windows.
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Just plug the dongle into the computer and wait for the device to be recognized. When the computer loads it up look for the "Run Setup" to appear on the desktop and click on that. After that just follow the on-screen instructions.
Check the manual and see the supporting operating system, may be your operaing system is not support you dongle, call to vodafone and get the latest driver for your windows.
I think that you will need to purchase another sim card for this dongle as you will not be able to pick up the south african vodafone internet from the UK
make sure the dongle is not locked to vodafone if you want to use another network
hope this helps
Try pluging the dongle, installing the software that will autorun (it's in the dongle memory) and let the software scan for the device. If it failed to regognize it call the vodafone helpdesk. Sometimes the dongles have problems. I suppose that they will change it.
