My medion 95924 keyboard is locked. I am unabe to type my password to access the net or type in a word doc. I've pressed various combinations - function, windows and 'L', being the favourite from help sites but nothing works and I can't access task manager.
Removing or deleting Trusted Devices from the Micosoft account fixed the problem. There were incorrect and incompatible settings from a previous tablet that were disabling the keyboard. From a different computer, sign in to Microsoft account, Overview, Security, Trusted Devices, select the hotlink Remove all the Trusted Devices associated my account. Refresh Windows completely. All fixed. It might be the same with your computer. Good luck.
Does the keyboard work in Dos mode or when you boot up goto set up and see if you can use keyboard to adjust settings
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
