Honeywell QuietCare HCM-630 Humidifier Logo
Anonymous Posted on Nov 01, 2009
I READ SOMEWHERE THAT YOU COULD SOAK THE FILTER IN A SOLUTION WITH VINEGAR TO GET RID OF THE ORANGE COLOR AND THE HARDNESS WILL THIS HELP OR SHOULD I KEEP BUYING A NEW ONE FOR 9.00 ????
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 02, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
392
Points
I SOAKED THE FILTER IN 1 C OF VINEGAR TO 1 GALLON OF WATER OVER NIGHT AND ITS NOT HARD ANYMORE BUT IT IS STILL ALITTLE ORANGE. SO I AM GOING TO TRY TO REUSE IT....
How to clean humidifier
I generally use White Distilled Vinegar. Clean your unit out the best you can with warm soapy water first and then soak or add the straight vinegar into the filter containment area and use a mild bleach solution for the water tank and soak and swish a little for 15 minutes then drain and rinse with fresh cold water and let air dry. The mineral deposits will slowly dissolve but will still take some scrubbing with a blue pan scrubbing pad or hard toothbrush. Depending on how hard your water is and if you use a water treatment additive will make a big difference in the cleaning process. Some people prefer to use distilled water in cool units as well as steam since it is almost completely mineral free and doesn't cost to much. Regular cleanings based on useage and water condition will greatly help the life and good operation of any humidifier including periodic filter changes if required.
Sep 26, 2014 • Humidifiers
1helpful
Inherited a Welbilt Ultrasonic humidifier and after reading all of the "sensativity" issues want to make sure to clean it properly....no paperwork came with machine.
For mineral deposits use a soak of vinegar
And water overnight. Scrub with a brush, and
Rinse well. To disinfect and get rid of discolorations, soak in a little bleach and water. Rinse well. A little secret from my pediatrician, use 1/4 tsp bleach with a full tank of water in use. It kills germs, bacteria and gives the mist a fresh smell. It makes
Cleanup nonexistent. And such a small amount will do no harm to babies or anyone. Use of bleach is the most common form of water purification. Google it, you'll see. I
Have a Welbilt ultrasonic humidifier. It is 20 years old and works just like new! Welbilt indeed!!!
Jan 25, 2011 • Humidifiers
1helpful
I have two questions. How do I properly clean my humidifier and recently it has started coating my furniture with a white powdery film. Why has it started that?
there is some cleaning tablets you can use periodically called protec beads ... cleaning can be done using high acid vinegar soak .. then hydrogen peroxide can be used on any mold .. this unit as well as ultrasonic type models will put out calcium dust if your water has calcium added or is hard water .. calcium is often added to water to give it a good taste .. one way to keep the unit clean for a long time is to use only distilled water .. and make sure there is no calcium added .. (read the small print on the container) .. its hard to clean the fan chamber in this unit .. lots of people complain about the dust .. the wick/filter type humidifiers dont put out dust but the calcium does accumulate on the wick/filter .. so you have to change that frequently (6-9 weeks) .. yours doesnt have a wick but still needs cleaned regularly ..
1helpful
2answers
How do I clean my hunter humidifier 33201? the filter blocks have white calcium? built up. I have sick kids and want it to be clean and running properly.
Soak the filters in a solution of 8 oz of white vinegar per gallon of water for about 20 minutes once per week and rinse well.
Better yet, do this once every 2 weeks, and on the off weeks soak the filters in a beach and water solution (rinse well) to keep the mold and bacteria growth from becoming a problem. I also add about a teaspoon of vinegar or a teaspoon of bleach (one or the other, not both at the same time) to the water when I fill the tank.
That helps keep the calcium scale from forming and it keeps the unit itself MUCH cleaner.
Hunter Humidifier #33222
From The Hunter Manual
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes.
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOUR HUMIDIFIER to continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
9helpful
How do I clean Hunter Humidifier #33222 ?
From The Hunter 3322 manual.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
1helpful
Not adding moisture to the air
Have you cleaned the unit lately? The following is from the owners manual.
16helpful
2answers
I need to know how to clean my filters on Hunter Humidifier Model # 33222. I have misplaced my instructions.
The instruction manual suggests using the water vinegar solution.
The following is from the manual.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location.
3helpful
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Filter dries out
2 things could be happening.
#1. Your water has gotten harder in the last year and more deposits are getting caught on the filter. Try soaking it in water and vinegar for an hour. This should clean some of the deposits out and extend the life of your filters. Everytime it gets hard try soaking it.
#2. Your machine is running out of water before you can refill. When this happens and the filters dry out, they aren't as good afterwords.
I would advise trying to clean them with vinegar and water and making sure your machine is always full.
Good Luck.
Top Honeywell Humidifiers Experts
Paul Carew
NOEL
NOEL
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
