Question about Wharfedale DVD-M3 DVD Player
Wharfedale dvdrhd400 problems
HI, I HAVE THIS WHARFEDALE dvdhd400 . WHEN SWICHT ON , I DO NOT GET A PICTURE , JUST SOME BLACK LINES . I DO GET THE SOUND OK .EVERYTHING ELSE SIME FINE. REGARDS. ADRIAN
  • Allan Kendrick Oct 14, 2008
    1.used low power to save electricity and turned off power in evening, after a few weeks my Wharfedale DVDRHD400 reset clock itself.
    2. no sound even when recording
    3. looked in setup and turned on progressive in frustration.Whoops no picture.
    4. Tried clear, clear, 6 (from manual) nothing happened
    5. overnight switchoff. Have now got sound but no picture, just a faint vertical black line on screen.
    6. tested tv / cables
    Still no picture - unit about 6 months old
    Please Help If You Can Regards Allan
  • 3 Answers
Posted by msladsy on Dec 21, 2007
Report abuse
When the initial set up ran for the DVD recorder it set the correct time and, I assume, the correct date.
However, I had problems with the display and went through various settings until I solved the display problem.
Unfortunately, during the process, which included disconnecting the power, the clock was reset, starting at midnight and 1st January. There appears to be no way to access the clock.
How do I get the recorder to display the correct date/time?
Mark
Comment by msladsy, posted on Dec 21, 2007
This solution may work for other Wharfedale DVD recorders as well as the DVDRHD400F.
Use your Setup button to acces the 'Setup' menu.
Choose the 'Preferences' menu.
Choose 'Factory Defaults' and click on 'OK'.
The recorder will restore the factory defaults and the first screen it takes you too is the 'Initial Setup' screen where it asks you to enter the correct date and time.
Mark
Comment by msladsy, posted on Dec 22, 2007
May work on similar dvd recorders. Would help if Wharfedale included this in their users manual.
Posted on Jan 28, 2008
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Posted on Jan 03, 2008
6ya staff
SOURCE:
Wharfedale tv
That sounds like the backlight is switching off. It might be faulty. If this is the case the screen still shows a picture but it's not lit, all black.
May 09, 2014 | Televison & Video
I just brought some wharfedale one-three speakers and have them hooked up as the rear speakers. Can i get the sub to play still and do i hook the speaker wires in the top or bottom?
Do you mean "Modus 13"?
See picture 6...
http://www.freeads.co.uk/uk/av/audio/hi-fi/speakers/8402337/wharfedale-modus-one-three-speakers-black-rare-bi-wire-quality/view
Put the jumpers back in as shown. Hook your speaker leads to either top or bottom. The entire array of drivers will be active.
Make your receiver aware they are LARGE for the purposes of bass reproduction so some bass will get out to them. FYI, many AVR's will only allow Large Rear speaker selection if you also have Large Fronts. Refer to the manual(s).
Mar 07, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
I have recorded a film and want to remove the adverts but i can't work out how to segment. It is the wharfedale DVDRHD400
Scan the DVDR with TMPGEnc v4.0 Xpress this way you can cut clip to you hearts content.
Jan 11, 2010 | Televison & Video
Wharfedale 80GB DVD HDD Recorder DVDRHD400 USER
remote not operating, unit working otherwise, h/d not full, dvd's play ok
Oct 26, 2009 | Televison & Video
Progresive scan problem and didn't get picture in tv
Our problem was that we could not get picture on the tv screen but it got sound.We tried to solve it using different techniques like the setup,video source,function keys pressed on remote control by trial(only assumed) and error as we could not see the screen and I used scart with every conection but three point pin was free so I put only one pin in video out put and at that moment I could see the picture on tv.
Jan 30, 2009 | Wharfedale DVD-M3 DVD Player
WHARFEDALE DVDRHD400
when you have split and seperated the part of the viceo you want to put onto a dvd, highlight it on the list of recordings and press the blue "playlist +" button on the remote. This will have added the recording onto the list of items to be recorded to dvd. Now press the red "RECORD/DUB" button. This will then record the file to the disc.
When y ou are notified that the process is complete,you will need to finalise the disc in order for it to be playable on other machines.
While the DVD is still in the drive uses the blue "function" button, and select DVD.
Shortly a list of titles on the DVD you have recorded will appear. Press the "UP" arrow on the remote once and a new menu will appear. One of the options here is to finalize disc. hilght this option and click the "RIGHT" arrow once - press "select" to finalise the disc.
Aug 30, 2008 | Wharfedale DVD-M3 DVD Player
where can i get a remote for the wharfdale dvdr hd400
Jan 15, 2008 | Wharfedale DVD-M3 DVD Player
Error code
I had the same problem - turn off at the wall and on again fixed it.
Dec 07, 2007 | Wharfedale DVD-M3 DVD Player
Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Jun 25, 2007 | Wharfedale DVD-M3 DVD Player
Wharfedale DVD-M3 DVD Player Logo
4,552 people viewed this question
Top Wharfedale Televison & Video Experts
Ekse
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
