Question about Kohler Toilet Seat - Elongated Front Quiet Close Quick Release - Cachet by
My slow closing toilet seat has stop closing slowly, it now slams shut, but the lid still works pefectly fine. Can this be fixed. I hate to have to replace the whole unit.
    New Friend:
  • 119 Answers
Call kohler they do have replacement cylinders
Posted on Nov 15, 2009
6ya staff
SOURCE:
Watermark soft close seat lid not soft closing
check with your local plumber or the manufacturer .
Apr 10, 2018 | Lid Home
Bemis whisper close toilet seat stopped being quiet, lid slams
This is probably a friction hinge. The slow closing feature is a result of friction within the hinge. So it sounds like the hinge has worn to the point of the friction being reduced. Another possibility is that some kind of lubricating fluid entered the hinge. If so, perhaps it will regain friction with time. Most likely the seat needs to be replaced.
Sep 02, 2017 | Bemis Home
My slow close toilet seat now slams shut. Are there any adjustments I can make to correct this problem?
WOW! Slow-close toilet seats. What will "they" think of next, to pick your pocket?
Slow-open mechanisms such as cassette players and top-loading DVD players use a special type of grease to achieve that effect.
The screen on the laptops uses a friction mechanism based on a "clutch-spring" with enough holding power to keep the display in the position selected.
This "clutch-spring" is factory adjusted so it neither slips under the weight of the laptop screen, nor is so tight that extra force is required to close the laptop.
These things do wear out, and as a rule are not user serviceable.
Can you adjust it? Good question!
Can you adjust it so it works? Ahah!
My rule of thumb: If it's already broken, how much more broken can it get?
Therefore, my conclusion is that the toilet seat's slow-close mechanism is factory set at the point where it will neither slam down nor stop half-way, but glide down gently until it's closed.
An interesting added feature would be for the toilet to recognise who's about to use it, and for what, select the seat position be it up or down, and then regulate the water volume needed to flush.
Also, it could flush itself once the lid is fully closed, to avoid or minimize the dreaded "toilet flush mist". arrrghhh!!!
Jul 04, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
The slow-lowering lid has reverted to slamming - can i just tighten the bolts to fix it?
If you want to be able to just tip the seat and let if fall without that loud slamming clank, look into getting some Drop-a-Seat cushions, a brand new product that is only $4.99 and absorbs the fall of the toilet seat and eliminates loud clanks. They're non-absorbent, have an easy stick-on installation, and are permanent but removable. www.drop-a-seat.com
Feb 24, 2011 | Toto Carlyle 1-piece Elongated Bowl Toilet
I have a Jika Mio soft close seat with a loose hinge which I cannot reach due to closeness of pan to wall!!
The top lid of my soft close toilet seat slams shut.How do I adjust Jiko Mio close coupled toilet.
Mar 27, 2010 | Villeroy & Boch Home
Slow closing toilet seat not working
It needs a new air shock on it. You might be able to take the old one apart and fix it but replacement would be best.
Feb 11, 2009 | Kohler Toilet Seat - Elongated Front Quiet...
Kohler K4761
Hello gsachs, Look under plumbing in your yellow pages for a Kohler distributor. Also here is the web page for you part numbers. You will need the hinge assembly. Copy and Paste to your address bar. Hope it helps!
http://www.kohlerserviceparts.kohler.com/ServicePartsPage.aspx?DocumentID=c83b1f213d0545f984b01b9f0be37b9d&ModelID=558da26604ce43ec98c83fe8ed0aa604
Jan 06, 2009 | Kohler - Toilet Seat - Avantis -...
Kohler Toilet Seat - Elongated Front Quiet Close Quick Release - Cachet by Logo
3,946 people viewed this question
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
