JVC Everio GZ-MG360 HDD Camcorder Logo
Posted on Nov 01, 2009
Loud noise makes my camera go into failure and the video that has just been recorded deletes. It asks something about ''recover-yes or no'' How do I respond or exit without deleting?? When deleted can I ever retrieve it??
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
7681
Points
27
Power off your camcorder, take the memory card or hard drive out of your cam, and connect it to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Then install this software Wondershare Photo Recovery (recover videos and audio files too) on your computer. Then start to scan and see if your deleted files can be got back. Get the program from:
For Windows Version
For Mac version
Remember - Do NOT try & write anything back to your camcoder(card or disk) until you can recover your files safely! Good luck!
1helpful
4answers
Accidentally deleted video from Cannon EOS 600D Rebel T3i
This recoverit data recovery can help to recover deleted video from Canon EOS cameras, connect your memory card with a computer, the recoverit would scan your memory card and find the deleted photos and videos.
https://youtu.be/vxg5MkA5wOo
3helpful
7answers
Can you recover deleted files from the Olympus Recorder VN-4100PC? also, one of my files is unable to play. any way of recovering it?
YES, it is definitely possible to recover such kind of files deleted from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to a PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. I hope this will help. Best regards!
Dcr sr200 deleted video by mistake can i retreive it
Yes ! Deleted recordings can be recovered using using software like 'Undelete Plus' or other recovery programs. If you don't know what you're doing, I'd recommend having the recordings recovered by a local professional or you can click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
2answers
WHEN UPLOADING ON MY FLIP ACCOUNT IT ASKED IF I WANTED TO DELETE ONCE THEY WERE UPLOADED. I SAID YES AND MOST OF THE VIDEOS DIDNT MAKE IT TO MY COMPUTER AND ARE NOW DELETED FROM THE CAMERA. CAN I RECOVER...
The answer is YES. Do it as follows.
First things first: DO NOT take any more videos with the memory card or hard disk (on your camcorder) that you want to recover videos from. Take the memory card or disk out of your cam and put it in a safe place. Because if you take any more videos or save any data to your memory card or hard disk, you may quite possibly ruin your chances of video recovery.
Then Connect the card or disk to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a data recovery utility that will recover your videos with Wondershare Recovery Software (I once used this program bounded with some other software) from the following link:
Video Photo Recovery (if you are running Windows OS)
Mac Data Recovery (from MacUpdate site)
Remember - Do NOT try & write anything back to your camcoder(card or disk) until you can recover your videos safely!
4helpful
4answers
Can i recover lost dictation?
Possible? YES, Easy? Not always.
First things first: DO NOT take any more dictations with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Hope my answer is helpful to you. Best regards!
3answers
I deleted seven voice files off my Olympus DS-2300 and need them back! Can they be restored or retrieved?
Yes, those voice recordings can be recovered provided not overwritten(if you keep taken more records, then possible). The best way is to try some audio recovery software. Here are some for your option. Both programs can also recover videos and photos.
Photo Audio Video Recovery Software (for Windows)
Mac Photo Audio Video Recovery Software (for Mac OS X)
Note: Before your audios are recovered, do not attempt to save more files.
3helpful
2answers
I recorded video on a Sony DVD-RW. 20 mins into
yes you can download it from google ... search in google for CD/DVD Recovery , software u will get it...download, install and Recover..
3helpful
Broken video management file/ recording failure
Although the instructions don’t make it clear, it seems to be important that the camera is turned off before you connect or disconnect the USB cable. The instructions do mention that you should not delete or rename files on the camera except in the EXT_MOV folder. The camera’s firmware is apparently quite fragile about file names and the presence of the extra hidden folders that both the Windows and Macintosh operating systems create when you delete something.
Panasonic AG-455 Problem
The noise is most likely bad bearings in the video head assembly. No longer available from Panasonic. The b/w recording problem is most likely caused by a bad video board inside the camera. Unfortunately, the video board is also no longer available.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
