If you bought the original PS3 when it first came out and purchased the expensive one with the larger hard drive, it will be able to play *some* PS2 games. If you bought the cheaper one with the smaller hard drive or purchased your PS3 once the prices started dropping, it will have no capabilities of playing PS2 games, as Sony has decided to not continue making the system semi-backwards-compatible.
When the PS3 was first released one of the consoles that you were able to purchase had backwards compatibility to play PS2 games. However that model was discontinued. The PS3's that had the PS2 compatibility where the 1st generation and the 2nd generation versions.
SOURCE: wont play ps3 games
I had this problem and it really made me mad. I tried re formatting , reset settings and nothing. Then I tried using some air sprayer that people use on computer key board and I sprayed in where the disc goes and now it works perfectly. Perfectly!
SOURCE: will not play any ps3 games or movies
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Thank you
