Computers & Internet Logo
Anonymous Posted on Oct 31, 2009
Boots up then shuts down windows critical error and goes back and off again
  • 1 more comment
  • Anonymous May 11, 2010
    Do you have any more particulars? Can you get into the system BIOS? Can you get in to the Startup Order setup, like Hard Drive, or DVD, because if you can boot from DVD then do it and see if the computer behaves normally. The "critical error" might go away if booting from DVD too.
    need more info. When did this start, did you down load a file from an unknown sorce. Can you boot into bios with out crash? ETC.
    more info please model is it in a system whats plugged into it unplug everything from mb sept power and video and keyboard then try
amafhh
Level 2:
New Friend:
  • Expert 115 Answers
  • Posted on Nov 01, 2009
amafhh
Expert
Level 2:
New Friend:
Answers
115
Questions
0
Helped
41639
Points
319
This problem is basically because of faulty heat sink.However it depend when the sys. restarts. weather it goes to windows and then restart or it restarts before windows logo if it restarts after windows boot procees you can try to reinstall the OS. or else you might have to replace the heat sink.
Testimonial: "thanks very much it was of great help"
1helpful
2answers
My computer came up with a blue screen that said system error said something about a physical memory dump and that it is shutting down the computer to keep me from losing my files, that was all I got from...
Not necessarily. This usually means an error somewhere in the critical operating system files. whether this is software problem or hardware remains to be seen.
Assuming that you will, sadly; not be able to access the operating system again, you can still access the files and get a back up using a hard drive adapter: http://www.coolmaxusa.com./productDetails.asp?item=CD-350-COMBO&details=overview&subcategory=converter&category=converter
This does involve having another pc to load the files onto. Once the data is backed up a format will indicate if its a hardware issue but hopefully the format will manage any bad sectors. Once the format is complete the hard drive can be placed back in the laptop and an OS can be reloaded.
This all is if you wish to backup, you can just load in an OS cd/recovery disk and let it format the drive and just Install rewriting over any data and formatting around any potential bad sectors on the drive.
Conputer is shutting down but it does not shut down
Hold the power button until the computer shuts down.
Restart and press F8 key repeatedly until you get a start up menu.
Select safe mode from the menu.
After the computer boots up, and you are at the desktop, go to my computer and select properties of the C drive (your system drive). Select tools from the tabs, then defrag. When defrag finishes, select check drive for errors and select the box, to automatically fix errors, and then ok, and yes at next window, allowing the computer to schedule the error check at next boot.
Reboot and allow computer to scan the drive.
After it finishes, you will continue into windows. Allow windows to boot. After it finishes, attempt to shut down again.
If it works, you fixed it. If not, you have a driver or program that will not quit, and you will have to research further to find out what is running and why it won't quit.
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
My computer wont load windows a problem has been detected and windows has been shut down to prevent damage to your computer. unmountable boot volume if this is the first time you seen this stop error...
Your Operating System probably corrupted due to unexpected power failure or any other reason. You may have to setup widows again.
Before reinstallation take backup of all necessary file in a separate Hard Disk from your (C: ) Drive , existing desktop , my documents , share folder, etc. to do this you have to connect you Hard Disk with another workable PC.
After taking all necessary backup, setup Windows freshly and it is recommended to format C drive during fresh setup.
Gateway laptop modle mx8711 windows failed to load
Try to start in safe mode and then when it finished loading shut it down again. Boot again it should boot to windows if it not, maybe a corrupted files or some files are missing.
1helpful
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
1helpful
2answers
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
On/Off problems
It sound as if there is a system file error. If you havent already, try booting up in safe mode (F8) on start up and when and if it allows you highlight 'Last known good configuration' and hit enter for a restart. If still nothing you need to insert your windows installation disc and hit enter when prompted. This will run a file installation, but not a format and when the files have installed you will have the choice to install windows or repair; select repair for system file installation.
Grand Canyon Tech
Grand Canyon Tech
