Yes, this is the way the flash can be used with the contemporary digital cameras. The camera has to be set to Full Manual mode (in point of the exposition), Exposure Time to 1/100 sec (or the shortest exposure that still assures full opening of the shutter). Aperture on the camera must suit the working aperture on the flash, also ISO speeds must match. The computer in the flash measures the reflected from the subject light and quenches the flash, creating the correct exposure. Mecamat sensor, having narrower reception angle and a sight, helps in achieving the correct illumination even on a relatively small subject. Sync voltage of Metz 45CL1 does not make harm to any digital camera, so you can use even the cheapest hotshoe-to-PC adapter available at many camera shops or you can buy one online. No need to spend much on sophisticated adapters.
If the unit will flash at all then you may be able to "re-condition" the capacitors or condensers. If so, then make sure you have a fresh set of batteries and trigger the flash in manual mode full light. As the capacitors heal and are able to hold more energy the light output will increase. If you are able to recover them then the voltage level will increase to where the light comes on. Otherwise they likely need replacing and this is work best left to a technician. This work is also expensive so you need to decide if it is worth it or simply replace the unit. Good luck.
I have tried a couple of external flashes on the 3000Z. It is my understanding from reading various Internet posts (and I am sure someone will correct me if I am wrong) that, other than triggering the flash to go off, there is no communication between the external flash in the hot shoe of the 3000Z and the 3000Z itself. Settings need to be made manually in the manual mode to set the f-stop and the aperture to get good exposures. The Metz flashes are expensive. Most have opted to use less expensive flashes such as the Vivitar 283/383, or a Sunpak, or even a "Wal-mart" flash. I chose an inexpensive bounce flash with a secondary "fill-in" flash to get rid of the shadows sometimes seen with indoor bounce flash pics. I purchased the Phoenix 82ZBDA Multi-dedicated twin flash from Porter's Photo Catalogue for $37.95. This flash works fine, but is not that powerful (GN 79 ). If you need a more powerful flash, you might consider the Vivitar 383.
