Https://www.appliancetimers.com/appliance?model=svd48600p
SVD48600P Gas/Electric Slide In Range uses timer part number 5700m662-60 or
Jenn-Air
SVD48600PC
02400173
Part No.
N/A
No power and buzzing relay.
Think getting in an electrician to check the unit out as it is a safety issue
SOURCE: Kenmore Stove Glass top
turn off the main break,them put it back on,that maybe resolve the problem.
I have thi's problem before and that's all I,did.
SOURCE: jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
SOURCE: Oven does not heat up
We may have found it - google Maytag Gas and Electric Range Service Manual (1997 models to present) and save it as a PDF to your desk top. Then print out the PDF pages # 18, 25 & 26, 52, 62 65 & 66. Those pages sound exactly like the problem we're having, which sounds identical to the problem you're having. We now suspect the issue is the gas valve heater coil and the volts it needs for ignition. Because without enough volts, the ignitor won't ignite (like, duh?). The specific PDF page is # 66 in reference to the Glow Bar Operation item # 4. If we're right, we'll need to get three small parts, totaling about $60 in all. Let's hope this is the solution!
SOURCE: Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
SOURCE: LOST POWER TO OVEN AND CONTROL PANEL
there is no reset buton ,but there are some basic things u can do.first u can chk the power coming into the stove.open the back and u will see power cord connected to the stove.use a multimeter and chk voltage between black and red wire.it should read 240v and black/red with respect to green should read 120 volt.if that is ok look for any burnt wires etc.if all is ok then most likely could have control board.
