SOURCE: Bosch dishwasher
check the salt cap is not split and tight. if this is o.k try to empty out the salt and use 3 in 1 tabs as they contain salt and rince aid
SOURCE: top rack not cleaning and spray arm possibly not moving
Hello--our Kenmore Elite has been showing exactly the same symptoms. Since it's under warranty I had a technician take a look at it, in fact he just finished putting it back together: problem was accumulated food and junk around the inlet filter to the pipe that leads to the upper racks. You can only get to this area by removing the lower spray arm, filter assembly, etc. until you are looking at the sump/chopper area. Any clogging should be self evident at that point.
This would be an easy repair for anyone with a few tools and the willingness to get into it. Seems to be working very well. We will be rinsing more thoroughly in the future...
SOURCE: cleaning out debri in pump
if youve acess below the filter screen ther is only 2 more screws holding down 2 more covers giving you acess to the chopper assy, this is where youll find broken glass and stuff hitting against hte chopper try to break up.. the first of 2 covers lifts right off,,, the second will require sorta prying up and off, beyond this no real acess to any more
SOURCE: dishes aren't getting clean, especially glasses on the top rack
check chopper remove bottom spray arm remove 4 screws take of cover then 2 more screws and the chopper is there.probably broken
SOURCE: dishdrawer leaves dried detergent and crud on
1-Go to diagnostic mode.
2-Press the Start /pause button until you get the display rd for Rinse Aid Dispense setting.
3-Have warm water readu in a kettle or a pitch.
open thedispenser to pull water in.
press the Lock button to turn the dispenser on.
4-Continue to pull water onto the dispenser holder so it can flush out all the resisdue.
5-When you feel that it is enough, press the Lock button again tostop it.
6-Press the power button to get out of this mode.
7-Start a Rinse cycle to completely flush out the residue from the inner tube to the sewage.
8 The next run you won't see the white stuff anymore providing that you will use the liquid not the powder...
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
