This trick works well on almost any padlock. Most thieves already know the trick so next time you buy a lock make sure that it's a fully deadlocking model which this trick cannot work with.
I hope that this has helped and ask only that you return the favour by rating my answer.
Don't know this particular lock but can you part chain with cycle chain tool? If not I would protect drive chain and gears and attack hasp with metal cutting wheel in angle grinder. Few locks can resist this for more than a few seconds.
Google "bicycle shifting technique", for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chain line is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chainline is as close to straight as possible.
Google bicycle shifting technique, for example:
Google bicycle shifting technique for operational advice, for example:
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency. To demonstrate this for yourself, put the bike in the same combination of gears you
