Hi when you start the pc and goes to the scsi utilities and scans for device its not finding the device attached to it sioit gives you this message you can see if the terminator connect to the device is properly connected and its in its place ,also press CTRL+A to get into the adapter setting and in the scsi utilities section scan the devices if it finds it then check the id of the device how much its set to it should not be the same of the scsi card id .by default scsi card id is 7 but be sure.
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
If you are using Windows XP, the drivers are embedded. It will automatically recognize the SCSI card. For other OS try
http://www.adaptec.com/en-US/support/scsi/2940/AHA-2940UW/
S. Mohan.
"Adaptec is the king
of SCSI connectivity devices and
currently offers two PC Card (PCMCIA)
SCSI cards. The 1460 is the
jack-of-all-trades model, ..." www.itreviews.co.uk/hardware/h82.htm
CPU: Intel Pentium III / Intel Pentium II / Intel Celeron slot1 ASIC: Intel 440BX AGP set Architecture: 3 xISA slots + 4 x PCI slots + 1 x AGP slos Max. Memory: 1 GB SDRAM for DIMMx 4 DIMM Type: 8/16/32/64/128/256 MB BIOS: AWARD plug-n-play flash ROM BIOS On Board I/O: 2 serial ports (UART 16C550 supported) 1 parallel port (SPP/EPP/ECP supported). 2 floppy drive supported (1.2/1.44./2.88 MB) 2-channel IDE (PIO Mode 4 and ultra DMA/33 bus master supported) 2 USB ports supported (universal serial bus) 1 PS/2 Mouse Port 1 PS/2 Keyboard Port On Board SCSI: Adaptec AHA-7880P ultra wide SCSI controller SCSI Port: 68-pin wide SCSI and 50-pin FAST SCSI connector yes Battery: 3V lithium battery Green Function: Yes Connector: IrDA, Wake On LAN, SB-LINK,Wake On Modem Board Size: 244 mm x 305 mm, ATX form factor
