If it has a drop down door, the only solution is to replace both door hinges, if it is hinged on one side, then the door catch, or door striker could be worn, these are easily replaced,
Please rate my solution.
Thanks.
Testimonial: "Thanks for your help.will try that."
When reinstalling door jiggle it up and you will feel the assembly click in to the correct lower slot. Once door closes properly you can push the locks back in to position and it should be ok. Well it worked for us.
SOURCE: Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
SOURCE: NEFF oven U1461 - The bottom oven door hinges do
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Thanks.
