You can convert between Standard Form (with fractions and pi) or
Decimal form by using the "S<->D" button. Use Mode 1 if you
mostly prefer fraction answers and you can use the SD button to convert
to decimal or use Mode 2 if you mostly prefer decimal answers and use
the SD button to see the fraction.
I hope this helps and good luck!
Please remember to vote Thanks.
SOURCE: I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
SOURCE: convert fractions to decimals
Hello
To convert decimal representation to fraction press [S<->D] key. Every time you press it it changes to the other format.
Hope it helps.
SOURCE: How do i convert fractions
To convert a single result to decimal, press the S--D key. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
SOURCE: How can I convert decimal
After you perform the calculations and press the = key, you can hit the ab/c key to toggle between decimal and fraction. Try .75= then you can toggle between 1/4 and .75
