I repeatedly get the message "Power Surge on Hub Port: A USB device has malfunctioned and exceeded the power limits of its hub port. You should disconnect the device." This is despite the fact that no device is plugged in. It doesn't seem to affect the functionality of the computer as far as I can tell but it is still concerning. Any advice on how to address this?
I am having the exact same issue. The disabling solution is helpful in removing the error balloons, but I lose USB funtion and whenever I require a USB connection, I must re-enable the device. The error does not seem to be having any affect on the connected equipment. However, the error balloon is very annoying. Is there any way to correct the problem rather than temporary disabling?
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer. WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at [email protected] for any further assistance on this issue.
I'll be glad to help you.
I have a HP Compaq nx6110 notebook. I have been facing similar pop ups "Power Surge On Hub Port". How can i solve this?
my MBox keeps saying
"power surge hub port" it want let me do anything how do i fix it
power Surge Error
Error message, the usb execede powerconsumption, even if there is and has not been mounted usb device since last restart / disabeling of the usb.
Later on it locks up the pc, and only hard restart can start the pc again.
Hi
I have Hp Compaq nx 6110 Laptop
but use device is not working.
whenever i was connecting USB device his shwoing error.
I HAVE A NX6110 AND I AM GETING ERROR POWER SURG ON HUB AGAIN AGAIN.
I have the same issue as the above, read error message: "power surge on hub port: a USB device has exceeded the power limit". the error message started when i had intially used the usb hub port (this was working well earlier". it has now started affecting my xternal HDD or mouse when connected. i think, it is USB 2.0 drivers, have done mormal updates from microsoft; OS: win XP
