Hitachi L32H01 32 in. HD-Ready LCD TV Logo
Posted on Oct 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Automatic tuning from new only brings up RTE1 & 2. How do we get the TV to tune in all the other stations. We are in Mayo and it seems that the Freeview is not working. Would appreciate your help, Patrick Conlon
Anonymous
Level 2:
  • Expert 83 Answers
  • Posted on Oct 30, 2009
Anonymous
Expert
Level 2:
Answers
83
Questions
Helped
27587
Points
207
Hi
press menu key on remot cantrol and selact your contry tuner system
EXP: USA / CANADA /SOUTH AFRICA / UK ./CHINA / INDIA ..and after selact contry. set chenal Auto serch and see all chenal is perfactly set
1helpful
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
1helpful
I have 2 alba tv/dvd combi's.1 in kitchen & 1 in bedroom.After digi switchover 1 in kitchen is fine after re tuning.The bedroom tv only has a few stations after numerous re tunes.Both work off
The one that does not work: have you tried to unplug it for a while from power and plug it back to see if it will reboot and allow you to program?
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
I Have a tv sony kv m1400, but i don't have the user manual,so i don't know how to tune the tv.
1. Press and hold down the [White Arrow Up] 'shift' button.
2. While held down press the UHF tuning button (symbol for button is ->).
3. Press + or - to tune up or down the UHF band as required, until the required station is reached.
4. Select a spare Channel Position.
5. Press [Arrow Up] & [UHF Tuning ->] buttons again to store and exit tuning.
You must use the remote control. No tuning is available on TV.
1helpful
Tunning in all digital stations
Don't know if this was the problem, but I was trying to go through the tuner for the saterllite stations. I tried going through the VCR/DVD unit and now all the channels are tuned. Only problem now is how do I tape a channel through the VCR? I can't seem to tune in the VCR.
Toshiba tv 2151tb how do i tune in stations
Toshiba TV 2151TB Tuning
Press remote button adjacent to the picture brightness button.
The symbol of a clock appears.
Press the button again and the >>> symbol appears, this is for course tuning.
Touch the Increase Volume button and auto tuning starts.
When a station is found two green underlines appear.
Type the station number i.e.for 2 type 02, this stores the station.
Touch the Increase volume button again to find the nexr station.
Upto 39 stations can be stored.
Fine tuning of any station is achieved by pressing the tuning button until three blocks sysbol is displayed.
Use the Increase/Decrease Volume buttos to fine tune the station.
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
1helpful
Alpine CDA-9833, how do you tune frequencies manually,
1 Press SOURCE/POWER until a radio frequencyappears in the display.
2 Press BAND/TEL. repeatedly until the desiredradio band is displayed.
FM1 FM2 AM FM1
3 Press TUNE/A.ME to select the tuning mode. (the play/pause
button above source/power)
Distance mode:
tuned in
Local mode:Only strong stations will be automatically tuned in
(Automatic
Seek Tuning).
Manual mode:The frequency is manually tuned in steps
(Manual tuning).
select manual mode to tune it one by one.
1helpful
2answers
How to manual tune the radio to a station and not use the scan
i have the exact same problem. i bought a fm transmitter, so i need to tune to a unused fm station in my region wich i cant do because the audi concert tunes up automatic and skips the unused stations ... HELP !
Cant tune my Hitachi TV
please check web site for any thing in remote. www.remotes.com and give model name in search. hopr this will help. good luck.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
