Luminox Field 821 wristwatch Logo
Posted on Jan 02, 2008
Luminox 8152 chrono
I have a 8152 luminox chrono. The hour dial located at at 9:00. One time it went around and reset. Now it wont reset. Also the large second hand sweep I cant get to set At 12:00 or ther positions. Is there something wrong with or how do you set the. The watch is new.
  • 1 more comment
  • Anonymous May 22, 2008
    I also have the same problem; although my small dial at 9oclock also get stuck. I am debating sending it back to the company I purchased it from. The watch is one week old. Any solutions?
  • Anonymous Jul 12, 2008
    Same here with the sweep hand. The large second hand does not always operate, and the button, at times, does nothing. It also seems to just stop moving, time wise, altogether.
  • jdaloo Mar 06, 2009
    I'm also struggling with resetting the hands on the chronograph. I am trying to reset the 'minute' hand (9 o'clock dial) on my 800 series. Using doods instructions helped- on my watch the start/stop operates the seconds and the lap/reset operates the 1/10 sec but I can't for the life of me figure out how to reset the minute hand and it is not set to zero on reset. Any guidance is appreciated.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1442
Points
22
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
8helpful
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
24helpful
2answers
Need to reset the tachymeter on my Guess Steel watch . The dial resets it's self to the "7" location instead of "12" on my watch. Is there a way to recalibrate the watch?
This is chronometer that's need reset. Tachymeter is usually located on bezel or inclined ring and is used for speed calculations of moving object over the given period of time. Ok, back to your chrono hand resetting. Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
7helpful
2answers
My analog stopwatch needle at 11 instead of 12o'clock
The procedure for the Classima Chronograph watch is different. You need to pull the dial all the way out, press on both buttons and hold for 5 sec, until the seconds dial makes a full cirlce (signalling that the chronograph is now ready for manual reset, then press the button on 2 o'clock until the seconds dial reaches the 12 o'clock position, then press button at 4 o'clock, to transfer control to the 1/10 dial, press button at 2 o'clock again a number of times until it resets to 0, then press 2 o'clock dial again to transfer control to the little hours dial, and press 4 o'clock button number of times until you reset this one to 0 too. Now just push back the dial crown to original position to close the operation. Viola
Dec 22, 2009 • Watches
Bezel won't ratchet anymore. Perfectly smooth
If this is stuck and just wont turn that means its full of yuk and muck and just needs cleaned ou, take to a good jeweler who can clean under the bezel...if it turns but simply doesnt click that means that the click spring mechanism is broken and would have to be sent to Luminox for repair...good luck :)
23helpful
How to set up time on TAG HEUER SLR CHRONOGRAPH ? what are the functions of the 2 boutons and 2 crowns ?
The crown at 3 o'clock is used to set the time and change modes. The crown at 9 o'clock is used to rotate the flange at the edge of the dial.
The A button at approximately 2 o'clock starts and stops the chronograph function. The B button at approximately 4 o'clock resets the chronograph.
Lap Timer: When the watch is displaying normal time, press the right side crown to switch to chrono mode (the hour hand will indicate CHRONO). This watch measures lap times, press A to start timing the first lap. Press A again to stop the first lap and automatically start timing the second lap (the hour hand will move to indicate you're on the second lap), and so on. You can measure up to 20 laps this way. When you're fininshed timing laps, press the right side crown to see the best lap time. To reset the lap timer, hold down B for 2 seconds. To switch out of chrono and see the normal time, just press the right side crown in.
Chronongraph: To time an interval that is not a lap, just follow the above instructions, but instead of pressing A to stop the first lap, press B and the watch will show the elapsed time to the nearest 1/100th of a second. Hold B to reset.
Crown at 9 o'clock: This crown rotates the inner flange at the edge of the dial and is used to measure total race time (i.e. the total of all the laps). Simply rotate the crown until the the little start trinagle on the flange is aligned with the minute hand. This way, the total elapsed time can be read at any time, similarly to how a rotating bezel works.
To set the time: Ensure the watch is not in CHRONO mode, if so, press the right side crown in. At this time pull the right side crown out until you feel a click.The position the second hand moves to indicates what is currently being set. If the second hand is at 9 o'clock, you are setting am hours, press A repeatedly to set am hours. Then press B and the second hand will move to 6 o'clock, pressing A repeatedly will set the minutes. So on for year (11 o'clock), month (12 o'clock), and day (1 o'clock).
4helpful
Setting alarm for Luminox 1848 Field Alarm Chrono
Normal 0 Here is the watch movement manufactures instruction .pdf.
RONDA startech Cal. 5130.D
http://www.ronda.ch/pdf/ba5130.De.pdf
2answers
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Luminox 8152 chrono
If new, just take back and exchange it for another working one.
Resetting the Watch after Changint a Battery
yes! I Don't recommend doing this yourself but if you open up the back you will see AC and a spot to touch with a twezer to short it out to the main plate.Then close the watch and pull the crown out and push the pushers in and out to set each dial.
The watch stops instead of the chrono
On this type of watch the second should not be working unless you are in the chrono mode. The lower dial should be the only indication of the seconds when not in chrono mode. You probably need to have the chrono reset and shown how the functions work. Try a Fossil location they will be able to tell you how to work this watch. It does not sound like this is a major problem.
Top Luminox Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Luminox Watch Expert? Answer questions, earn points and help others
