it will do it will keep going till engine cools its surposed to do this it will shut when its cool , if it still does it after its cool then u need to replace temp sencor it on side of rad
It would depend on what failed. Timing chain, crank bearing, piston, etc. Unless one of the accessories locked up and the belt is the only thing holding it, you would probably have to take the engine apart to fix it. Once in a while the alternator or water pump will seize up and the belt will keep the crank from turning.
Check the fluid.Change the fluid and filter and see if it gets better.If it does then I would recommend a fluid transfer.This will transfer the old fluid and add new fluid.Hope this helps.Good luck.
Possibly in a "Safe" or "Limp home" mode. If so, have a look at the wiring harness on the transmission. I'll bet that the seal around the lid on it is failing. Clean the harness up, and reseal the lid on. If this does not fix it, have a mechanic look at the shifter linkage.
you need to verify the dome lights are turning off before you walk away,something is draining the battery.check you car out after driving it and make sure radio and any other things all shut off.
