SONY REAR PRO FW51M31 RED STANBY LIGHT BLINKING 10 TIMES OVER WHAT IS ABOUT TO HAPPEN. IT TURNS ITSELF OFF ONLY ONCE WHEN STARTED THEN IS OK.RED LIGHT STILL FLASHING
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Mar 17, 2012 - 14 posts - 4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Hi, my name is John. Welcome to FixYa. You have a problem in the D board. I will post what you need to check here, such as the transistors, capacitors etc. thanks for choosing FixYa....John
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
THERE ARE NUMEROUS COMPONENTS WHICH MAY CAUSE YOUR PROBLEM. EXPECT $300 - $400 REPAIR BILL
TAKE SET TO SONY AUTHORIZED SERVICER.
30 YR SERVICER
APGONZO
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
