Go to "Lexmark solution center", then go to maintenance, then "install new cartridges".Check "No, this is new" option on cartridges and ink level will reset.
I go to "Lexmark solution center" , i go to maintenance and i click on
"install new cartridges" but it shows me only instruction how to put the cartridge.
SOURCE: ink level reset
if you are useing a refilled cartridge , ink cartridge has a chip built in that must be reset, if you look on line you can purchase a reseter. if you use a new ink cartridge it will show a full ink level
SOURCE: Lexmark x5470 all in one printer-low ink level
we have a link on how to fix your own printer through this link(check for search box further down page)
SOURCE: need to reset ink levels on printer (lexmark 2600)
Hi
It is the chips on the inks that make it shore empty nothing you can do about it.
But I have found this bit of read up on the internet forum Gave it a go may work if it works come back let us know so I can pass it on to others Thanks.
1 Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one.
2 Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
3 I had fully covered the contacts because it was the full length of my Scotch tape. It did not work. I went back and re-read thread, wiped the contacts the computer was telling me, took off the strip and put on just a sliver covering the left vertical side of the contact only. It worked! Yippee! Thanks a million!
Go to this website to see all
You can go to this link to see all the read up about it.
http://www.fixyourownprinter.com/forums/inkjet/35235
I not have this printer myself so I not can say if it works or not.
All The Best Hope it works for you
