CD PLayer won't play CD's
Hi
First of all, you must find all the screws for the top cover and remove it. Make sure the unit is not plugged in!
Then, making sure that you are not touching anything inside the unit, plug it back in,put a Cd in the drawer, and watch what happens. If the drawer closes, but you can still hear a motor running, then it is a belt drive unit, and the belt is slipping, if that part is ok, listen carefully for a ticking noise, which is the laser lense going up and down trying to focus on the CD, if the disk starts to spin then the mech has closed properly, and the unit is trying to find the directory. If the unit then spins the disk for a while then ejects it, then the laser is dirty or faulty. I would suggest getting it cleaned at a shop if the lense appears dirty.
***Never look straight down at the laser lense if it is exposed on your model of CD player, it is a class 3 laser, and you will be doing some harmful home laser surgery to yourself!!!***
Hope this helps!
Good Luck!
P.S. When following the steps above, if you hear the ticking of the lense moving up and down, but the disk does not spin, gently spin it clockwise with your finger, if it starts to play, or finds the directory, then the spin motor is bad.
