to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
There is no override code. But maybe a override key the normal key is to open the bolt after the correct code is entered. Cracked or drilled. Call a locksmith to help. Don't fall for the biggest add in the phone book a good locksmith could never afford a full page add and offer a good price.
Do you know,you needs only four steps to unlock the Samsung
SGH-A767 (Propel) on at&t Network?It is so simple!
Step 1:Power on without SIM
Step 2:Type in #7465625*638*Unlock code# (8 digit unlock code*)
Step 3:Device should say: “Network Lock Deactivated”
Step 4:Phone may automatically reboot
hello 1_ can you save your formation in other phone . 2_that code format your phone for Nokia only 3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345 4_ other numbers *#7370# and the security n ...... and look if the problem is solve it because after this . you have like a new mobile
I just figured this out after having my blueset linked with my old phone. I couldn't remember my password for the life of me to connect it with my new phone. Finally I turned on my bluetooth headset and then held the call button for about ten seconds. After that I proceeded to search on my phone for the bluetooth and link it. The password is 0000. I hope that helps!
