Televison & Video Logo
Posted on Oct 29, 2009
Tryin to program my all4 one remote to my toshiba remote need code to do it please
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Oct 29, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
3311
Points
69
Go to oneforall.com and look up your remote. They'll have a PDF available listing all possible codes for your TV.
I need a manual for the Toshiba ct90121 remote control please
The directions for programming a television remote like the CT-90121 will be in the manual for the TV that it came with. One such model is the Toshiba 36HFX72. The manual for this TV is available at ManualsLib here: https://www.manualslib.com/manual/172528/Toshiba-32hfx72.html#product-36HFX72 . The directions for using the remote starts on page 14, https://www.manualslib.com/manual/172528/Toshiba-32hfx72.html?page=14#manual . The remote control programming directions start on page 17. The device codes start on page 19.
Please note: universal remote code lists are usually limited to devices that were programmed 6 months or more before the universal remote was programmed. Since the 36HFX72's manual has a copyright date of 2002, the CT-90121 may not control devices built in late 2002 or later. I hope this helps.
I need to program my Toshiba TV with a connect it rm500 remote control and I don't have the codes list. Please help!
TOSHIBA TV 3 Digit Remote Control Codes:
013
049
089
105
109
117
118
120
159
178
TOSHIBA TV 4 Digit Remote Control Codes:
0260
0358
0394
0924
0398
0983
0973
2answers
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
1helpful
I can't program my remote. My tv is a toshiba. I
There is only one code for Toshiba programmed into the URC4110 remote: 0000
If this code doesn't work or you have a different One-for-All remote, please post back and I will try to find another code or get the correct codes for your actual remote:
Regards,
BElectric
2helpful
2answers
I have a toshiba regza hd ready flat screen tv. Need to program the sky remote for it but do not know the model number. Can't find it on the tv anywhere or find the manual! Any ideas on how I could find...
The model number should be on a white sticker on the back of the TV. If you can find it, please post back and I will obtain the correct code for your Sky remote.
There are some Generic codes for Toshiba TVs which are:
0536 1536 and 1221 for Rev 8 remotes
0063 0536 and 1121 for Rev 6 remotes
0063 0121 and 0536 for Rev 4 remotes
You can find the Rev number of your Sky remote on a sticker inside the battery compartment. If it just says RC1600/00 then you have the original Sky remote, but you can still try the above codes.
If you need instructions on programming the remote, please post back with both your model number and Sky remote Rev number and I will post the codes and instructions.
Regards,
BElectric
1helpful
3answers
Tryin to program remote and cant find the instruction
I NEED HELP WITH A PHILPIS UNIVERSAL REMOTE......TRYING TO PROMGRAM IT WITH ESA TV
14helpful
3answers
Toshiba CT-877 Remote
http://remotes.com/remotes/documents/Toshiba/CT-877.pdf
2helpful
Need code to program toshiba tv with Direct tv remote
I HAVE A TOSHIBA 32A33 TV AND JUST UPGRADED MY RECEIVERS AND REMOTES I CANNOT GET THE DIRECT TV UNIVERSAL REMOTE RC64 CODES THAT THEY HAVE PROVIDED TO WORK, ANY ADDITIONAL CODES ? PLEASE HELP
2answers
Need code or codes for my Philips Universal Remote to a Toshiba TV
please tell my what code for philips universal remote pm 435s?for my tv sanyo?thanks?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
