Shearing of flywheel key on starting 12 hp snapper engine . When key replaced runs a few senonds then shears again. First sheared when lawnmower blade belt slipped off pulleys and became tangled with drive belt putting stress on motor
When you the key this time, put the flywheel on first then the key but this time use a little grit between the flywheel and crankshaft. Something like grinding compound. It will keep the flywheel from moving plus make sure you torque down the flywheel nut good.
HTH
Good Day.
If it is not torqued properly it will continue to shear keys
