If by "won't stitch" you mean that the top thread will not pick up the bottom thread, make sure you have the needle threaded properly. If the machine is a top loading bobbin, the thread goes in the needle from front to back. Same if it's a side loading bobbin (bobbin faces you as you sew). If it's a front loading bobbin (bobbin faces left of machine), the thread goes in the needle from left to right.
Hi. I did not have this exact problem with my Featherweight. My machine was not stitching properly (top stitch looked so-so, but lots of thread bunching on underneath side of fabric). I took it to repair shop and learned that I was threading the needle thread on the wrong side of the metal plate which is part of the take-up arm (I do not think that the threading instructions make this distinction). After the repairman pointed out the problem & threaded the machine, it made a proper stitch.
My suggestion for this issue: check the bobbin threading. My bobbin has to be inserted so that it turns counterclockwise in order to catch the down thread.
Is this the first time you have used the machine? If so you need to bring up the bobbin thread by hand before stitching. Only when both bobbin and top threads are up through the needle plate nad pulled towards the back of machine, will the machine form a stitch.
make sure that you have enough of a tail on your thread, at least 3-4 inches and hold it with your left hand until the needle picks up the thread. I am assuming that you have your bobbin threaded correctly and your needle is inserted with the flat side facing the rear of the machine.
Sometimes even though the tension is at recommeded placement, you may find with various fabrics or threads, you have to adjust it. I would try to raise the tension just a bit. Try it a little at a time until you achieve a stitch you are happy with. If adjusting the tension does not correct the problem, double check your threading. If sure it is threaded properly, especially going through the tension assembly...check your thread. I have found that the thread you use can and often does create tension problems. Try changing the thread and see if the stitch quality improves.
I believe it is recommended to hold each thread until the stitching gets started, see your manual. I make sure the slack is removed from each thread just before putting the presser foot down, then just put a finger on the threads, clamping them between your finger and the sewing bed, until a few stitches are done. This can be done through the material being sewed.
What does "doesnt have good sewing results" mean? Is the stitch loose? Does it skip stitches? is the tension balance off?
The serger "It doesnt sew right" rule of thumb: replace your needles, make sure they are inserted all the way into the clamp (one will be hight then the other) and orientated properly (eg. flat to the back), COMPLETELY unthread machine, re-thread!!!! re-thread!!!, check for proper threading (make sure thread is in tension discs if possible), change your thread.
Improper threading is the #1 problem causer. I cant stress it enough. Rethread Rethread Rethread!
