SOURCE: CCD used in the DiMAGE E201?
The DiMAGE E201 uses a 1/1.75-type interline primary color CCD with a total of 2.3 million pixels.
SOURCE: showing battery low
hi anjali,
i think the problem must be with the replacement of the CCD chip. they must have must some damage to the cam with out their knowledge. but the thing is you cant even claim that with Sony. you must have took it right next day.
that too if you are in india you cant expect the service people to get these things fixed so soon. you must have been attentive.
SOURCE: Konica Minolta Dimage 7Hi - Faulty
It could (note I'm saying could, not is) be a bent flash card pin. If you get it, take a look inside the camera's CF card slot. If a bent pin is spotted, remove the batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Now if you get it and there's NOT a bent pin in there (say it's a missing pin, a very different story) don't come back crying here! :-)
SOURCE: Showing low battery
I had similar problem with my Minolta camera. There is no way to fight with them. DO NOT DEAL WITH SONY ANYMORE, my best answer. It looks like Sony has special position on support own products. We have to start consumer's protection company against of SONY. Personally, I used to sped more then $10,000 to by Sony's staff, if it works - it works, otherwise you are in trouble if you do not have extended warranty. NEVER BUY SONY!
SOURCE: i have a dimage 7hi
This doesn't sound good. You could be having a problem with the lens, or with the ccd (image detector inside the camera. You can take it in to a camera repair shop and see what they think, and how much it might cost to fix it. You can also contact Konica Minolta to see how much they would charge to have it fixed. Here's their website:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Good luck, and hope this helps you.
