Question about Lexmark X4650 InkJet Printer
Tyring to set up on multiple laptops Lexmark X4650 all in one
Im trying to set up the printer on multiple laptops. I set it up on the first but now when i try to set it up on the second it says the wireless network is already in use. even if the first laptop is not turned on. i tried connecting in through the usb cord but that didn't work either. it said something about the wrong port.
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 432 Answers
SOURCE: No wireless printer port for lexmark x4650
Your firewall for the wireless is blocking the port. Go into your firewall settings and add the port from the printer to bypass the router. What operating system do you have? It should be in Control Panel under Security Center.
Let me know.
Ray
Posted on Feb 03, 2009
Anonymous
  • 17 Answers
SOURCE: can't scan to PDF
I would suggest scanning each page into their own file, convert each into a .pdf, and then using a free program to combine the .pdf pages.
Search download.com
Posted on May 28, 2009
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: lexmark x4650
You can download the required installation drivers from manufacturer's site by clicking this link
On the page which opens, select the operating system (Windows XP/Vista,etc..) of your computer from the drop-down menu and download the appropriate drivers and software.
Hope this solves your problem. Thanks for using FixYa.
Posted on Feb 24, 2010
elix0411
Jose Cada
  • 3530 Answers
SOURCE: i lost the power cord for lexmark x4650 printer
Welcome to Fixya
You can actually order the particular cord at Lexmark support. The part number for the cord is 11B5626.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Oct 02, 2011
I have a Lexmark X4650 InkJet Printer I need to find a driver to install
You can download the drivers for your Lexmark X4650 at www.Lexmark.com. Just choose the Operating System of your computer.
May 03, 2012 | Lexmark X4650 All-In-One InkJet Printer
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
I have a dell laptop with windows xp and just bought a lexmark x4650 wifi printer, still in the box from a pawn shop. my computer doesnt recognize it, but thinks its a different model. ive tried googling...
Please visit the Lexmark website to download and install the Lexmark X4650 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Sep 30, 2011 | Lexmark X4650 InkJet Printer
Gen you send me driver link for printer x4650 lexmark
Try this link: http://support.lexmark.com:80/lexmark/index?page=content&locale=EN&docLocale=en_US&segType=recommendedSegmentMICROSOFT&userlocale=EN_US&id=DR2728
Assuming you are using Windows that should be the appropriate driver set. Click the download link and run the .exe file once it is finished downloading.
Aug 18, 2011 | Lexmark X4650 InkJet Printer
Hi their, im matt Right, i reinstalled everything on my computer because i wanted to start a fesh installation. Im running windows 7 ultimate 64bit. I have tried to reinstall my printer but no look. I...
Check if your printer is still connected to the same network as your computer. Refer to this article: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs). If you the printout, check the SSID and other network information. If printer still belongs to your network, then it could be a firewall issue. Make sure to allow all Lexmark and printer communications in the program rules/permissions for your firewall. If printer doesn't belong the same network as your computer, then you need to reset the printer's wireless network adapter and re-launch the Lexmark Wireless Setup Utility. How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults
May 29, 2011 | Lexmark X4650 InkJet Printer
My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
May 23, 2011 | Lexmark X4650 InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
Hi i want to no if the lexmark X4650 supports spanish ?
If you're asking if the Lexmark X4650 supports spanish language, yes. You can set the printer language by pressing the Setup button -> Device Setup -> Language -> select Español -> press Ok button.
Apr 06, 2011 | Lexmark X4650 InkJet Printer
Just installed software cd for lexmark X4650 on laptop with windows 7 64 bit. Productivity Center app won't work. setup wireless print - works fine. Get a popup that says to download m.NET Framework 2.0...
You will need to use the Lexmark X4650 driver for Windows 7 64-bit from the Lexmark website. First, uninstall the existing driver from your pc. Go to Start menu -> Programs -> Lexmark 4600 Series -> Tools -> Uninstall. Reboot your pc when prompted.
To reinstall, click on this link Lexmark X4650 Driver for Windows 7 64-bit. Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Jan 13, 2011 | Lexmark X4650 InkJet Printer
I intalled windows 7 64 bit on my laptop and when I try to download the drivers from Lexmark, the printer isn't available. I also can't connect through wireless. Can you help me?
What is the status of the wifi light on the printer? orange or green? blinking or steady? For the Lexmark X4650 Windows 7 64-bit driver, click on this link Lexmark X4650 driver for Windows 7 64-bit. Download, execute the file and follow the instructions on the software. Thanks.
Jan 03, 2011 | Lexmark X4650 InkJet Printer
Lexmark X4650 InkJet Printer Logo
98 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
