My battery pack on my fold n go mobility scooter ( same battery pack as older shopridder) has a short and keeps blowing fuses. I put new batteries in it, but something seems to be shorting out. Need help please. Thank you!
Hi, ok now you need to check your wiring within the battery pack ,
If there are two batteries, you need to make sure that negative wire of one battery connects to the positive of the other battery,
now use the postiive and negative battery connections to connect to the scooter , that will give you your 24volts,
battery 1 connects battery 2
== 24Volts
use the + of battery 1 & - of battery 2 to connect to the scooter.
Regards
GeWiz.
Testimonial: "Thank you for answering. "
