Yes if you turn the oven on bake that element should heat pretty quick, if not its toast..
if i had a model # i could be more specific but generally all you'd need to do is turn off the breaker or unplug the unit.
remove the screws that hold it to the rear of the cabinet, and slide the element straight back towards the front enough to expose the screw or slide on connectors.
now you can either remove 1 wire at a time and have the new element sitting under the old one and transfer then as you go, or remove 1 wire and bend if over some so it won't slide back into the unit and get lost..
after the wires are reconnected slide the element back into place and replace the screws and restore power and cook..
hope this helps,
best of luck,
ttfn
