Heating & Cooling Logo
Posted on Oct 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Carrier hvac does not come on.
My HVAC when turn on then hear the click sound from the unit then it work fine but lately when turn on i did not hear the click sound and it's not working . Could you tell me the problem? Thank's.
Ken Thomas
Level 2:
  • Expert 118 Answers
  • Posted on Oct 29, 2009
Ken Thomas
Expert
Level 2:
Answers
118
Questions
Helped
48006
Points
228
That sound was the contactor closing, check the outside wires make sure they haven't been cut or ripped off unit. Buy a generic a/c contactor and connect it to the low voltage wires and see if it will click. if so install it the same as the old one after shutting off high voltage. If it doesn't click it is in the wires 90% of the time!
HVAC blend door or control module?
The symptoms you describe, such as the flashing amber light on the defrost knob, loss of airflow, and clicking sounds when opening the driver's door, suggest a potential issue with the blend door or the blend door actuator in your HVAC (Heating, Ventilation, and Air Conditioning) system. The blend door is responsible for directing the airflow between the various vents, including the defrost vents, dash vents, and floor vents.
Here are some steps you can take to further diagnose and address the issue:
1. **Blend Door Actuator Inspection:**
The clicking sound you hear when opening the driver's door might be related to the blend door actuator. The actuator is a motorized component that controls the position of the blend door. Check if the clicking sound is coming from the actuator. If you can access it, inspect for any visible damage or obstructions.
2. **Check for Obstructions:**
Sometimes, foreign objects or debris can obstruct the movement of the blend door. Check for any visible obstructions in the HVAC ducts.
3. **Perform HVAC Self-Test (if available):**
Some vehicles allow you to perform a self-test on the HVAC system. Refer to your vehicle's service manual for instructions on how to initiate a self-test. This may provide additional diagnostic information.
4. **Inspect Wiring and Connectors:**
Check the wiring and connectors associated with the blend door actuator and the HVAC control module. Ensure there are no loose connections, damaged wires, or corroded connectors.
5. **Professional Diagnosis:**
If the issue persists after the above checks, it may be advisable to seek professional diagnosis from a qualified mechanic or a Jeep dealership. They can use diagnostic tools to retrieve fault codes and perform more advanced testing on the HVAC system.
6. **Consider Blend Door Calibration:**
In some cases, the blend door may need recalibration after a control module replacement. Refer to your vehicle's service manual for instructions on how to calibrate the blend door system. Calibration procedures can vary between vehicle models.
It's worth noting that even though you replaced the control module, the issue may still be related to the blend door actuator or the blend door itself. The clicking sound when opening the door suggests that there may be a connection.
Remember to consult your vehicle's service manual for model-specific information and procedures. If you're not comfortable with the diagnostic process, seeking assistance from a professional mechanic is recommended.
Heater ac fan won't blow 05 silverado. Started truck on cold day fan was blowing and turned it off waiting for truck to warm up and heater would not come back on. Checked all the fuses, all were good. Fan...
Test the electrical circuits ! Manual HVAC or automatic HVAC ?
Do you know the difference ? Heater / A/C blower motor electrical control diffrent . Manual has resistors an a relay for different speeds , automatic has a blower motor control module .Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info year , make , model and engine size . Under system click on HVAC ,then under subsystem HVAC controls will pop up . Click the search button , then the blue links . First off you need to know what system yours has , manual or automatic.
GMC Yukon HVAC Blower Motor Won Turn On
Blower Motor Problems Auto Repair Help
American standard Hvac not working but a/c is working
I'm guessing this is a heat pump? Possibly outdoor board is faulty??? Tstat not setup for heatpump???
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2helpful
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
3helpful
2answers
I have a 04 acura and the lights in the radio clock an heat controls does not work.
ACURA Service Bulletin
04-021
Applies To: 2004 TSX - From VI N JH4CL9...4C000001 thru JH4CL9...4C028982
July 9,2004
Audio-HVAC Display Module Is Dim or Dark
SYMPTOM
The audio display and controls (knobs, buttons, bars)
of the audio-HVAC display module are dim or are dark.
PROBABLE CAUSE
Faulty audio unit.
CORRECTIVE ACTION
Replace the audio unit. Refer to S/B 87-015, Audio Unit
In-Warranty Exchange/Out-of-Warranty Repair.
If a client calls ahead to schedule an appointment, and
the vehicle is in the affected VIN range, order the
remanufactured audio unit right away so it is available
when the client comes in.
PARTS INFORMATION
Order the appropriate replacement audio unit:
NOTE; The audio unit is listed as a Tuner Assembly in
the Interactive Network (/N) Parts Catalog. This unit is
both a tuner and a 6-disc CD changer.
Tuner Assembly (without navigation system):
P/N 39175-SEC-A02RM
Tuner Assembly (with navigation system):
P/N 39175-SEC-A82RM
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies
Operation Number: 010149
Flat Rate Time: 0.5 hour
Failed Part: Use the RM part number (from the
repair order) without the RM.
Example; 39175-SEC-A01
Defect Code: 03214
Symptom Code: 03272
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starlina work.
REPAIR PROCEDURE
1. Go to S/B 87-015, Audio Unit in-Warranty
Exchange/Out-of-Warranty Repair, for guidance on
how to get the remanufactured audio unit.
2. if you can read the audio display, write down your
client's radio station presets.
3. Remove the audio-HVAC display module (see page
22-267 of the 2004 TSX Service Manual). (In ISIS,
use the keyword DIS MOD, and select Audio-
HVAC Display Module Removal/Installation frorn
the list.)
4. Remove the faulty audio unit from the audio- HVAC
display module (see page 22-268). (In ISIS, use the
keyword DIS PAN, and select Audio-HVAC
Display Panel Removal/Installation from the list.)
5. Transfer the left and right brackets from the faulty
audio unit to the remanufactured audio unit. If the
remanufactured unit has a shipping cover and
shipping screws, make sure you transfer them to
the faulty unit being returned.
6. Install the remanufactured audio unit in the audio-
HVAC display module. Then reinstall the audio-
7. Enter the anti-theft code for the new audio unit.
Enter your client's radio station presets if you
recorded them in step 2.
8. Make sure all of the functions of the audio unit and
HVAC work properly.
9. Replace the sticker on your customer's anti-theft
radio identification card with one of the new stickers
that show the anti-theft code. Apply the other
sticker that shows the anti-theft code onto the
vehicle history file copy of the repair order.
10. Remove all old serial number stickers from the side
of the glove box or inside the center console. Then
apply the new sticker that shows only the serial
number to the side of the glove box.
11. Return the faulty audio unit to the parts
department. Refer to S/B 87-015 for parts return
in structions
1helpful
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
