When disc inserted reads Wrong Disc
Since 4 days I've searched 99% of internet to fix 'Wrong Disk' solution for my DVDV822-05 Player, but I could not get any such solution. Some solutions for other players of the same company is to change region codes but I could not find these codes for this particular model. I got this player from some other country which I dont know. It's sayying 'Wrong Disk' to all disks either MP3, audio, VCD, DVD etc. It's my humble request to all e-guys and companies to find some solution for this model.
It means the disc is not a format the player supports, or has no playable files.
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
SOURCE: when i insert a disc in my dvd player it reads "no
Hi mgarragh1, Ifyou already cleaned the lens, and confirmed
that the ribbon is good as well as the motor then I would advice you to send it
to repair shop because the next step should be done with an expert because it is quite
technical diagnosing the fault between the pick-up lens and the main board.
If you have necessary tools and test instruments,
know safety precaution in basic troubleshooting try the steps below to solve
your problem.
Assuming that the disc is good.
1.Clean the lens. -
Sometimes because of dust the lens can't read any disc. Try clean the lens by
soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check
the ribbon connected to the lens from the main board for scratch,
damage. Once it has an open line then of course the lens can't read the
disc. Also try to erase the contact by pencil eraser. If you've done the steps
above and the symptoms still there then the next step requires you a little
knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check
the motor that spin the disc with an ohmmeter. You can test it using the
ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading
should be fairly high and it will spin. Bad
motor- reading will drop to low resistance and will not spin.
Hint : 50% of my
repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor
then replace it with a new one. Before replacing the new motor you have to
check the clearance of the disc holder with the old one. The clearance should
be the same as the old because if not the lens will not read the disc if it is
too far or too close.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
i put the disk in and turn it on it says loading and then comes up with "wrong disk." How do i fix it? I have tried everything I can think of.
does not read DVD-R any more, does not write DVDs any more
wrong disk
PLAYER WAS WORKING FINE PLAYING ALL DISCS WE PUT IN NOW NO MATTER WHICH DISC YOU PUT IN SAYS WRONG DISK EVEN THE ONE WE PLAYED BEFORE.
We put a brand new movie in, and player started to shake during loading. and reported "wrong disc" on the screen. We took the movie back for a new copy, and same thing happened. We cleaned laser, unplugged player, etc... always the same result. The weird thing is that it still plays all of our old movies, HELP?!
wrong disc message
The "wrong disc" error shows up - for the same DVDs that it was playing before and for new ones. Nothing happened in the meantime; meaning no move; no moving/dropping/rattling the DVD player. Tried turning the power off and then on again, disconnecting from the power strip, etc. but nothing helped.
When
ditto
I bought it the begining of Dec. 2009 and before Christmas it said Wrong Disc. Will not read any at discs at all. Burned, new, old. cd or dvd.
good DVD's but wrong Disc
