SOURCE: Zebra 105sl - printer does not print correct size
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
SOURCE: Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA
^PRC
^LH0,0^FS
^LL203
^MD0
^MNN
^LH0,0^FS
(Design No. 1)
^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS
^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2)
^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS
^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3)
^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS
^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS
^PQ1,0,0,N
^XZ
^FX End of job
^XA
^IDR:ID*.*
^XZ
I hope this will help you solve your problem...
SOURCE: Printer S4M only prints the code in stead of the label
I have just tested this code in my printer and it works fine.
Make sure that your S4M is set to understand ZPL code and is not on dump mode.
Perhaps performing a full reset on it will cure the problem.
SOURCE: PRINT WILL NOT STAY ALIGNED ON EACH LABEL-RUNS ONTO NEXT LABEL
Check the tension on the Ribbon Take-up Spindle there is a nut on it that sometimes can loosen or tighten its self and will throw off the lables. Its a nut that has a of couple Hex nuts on the corner, screw the nut to about the 3rd thread from the top of the bolt facing you then tighten the hex nuts on the corners of the nut. Then try printing the labels make sure the media guide also is set to the lable size that is installed.
SOURCE: TLP-2844-Z only prints using EPL2 not ZPL2
Download firmware, get latest firmware & Firmware download utility software directly from the Zebra website
