Help! My stainless steel Jenn Air Dishwasher has rusty spots on the outside handle and the area just above the handle on the outside door is all blotchy. I use a stainless steel cleaner but it doesn't help. What can I do? Should this be happening on an $1100 dishwasher?
Check out this site I hope this helps.
www.applianceart.com
these guys sell covers for your dishwasher that are vinyl and magnetic and will even create a protective covering for your dishwasher front.
I would try a product called Evapo-Rust! Evapo-Rust will remove the rust without damaging the stainless steel finish on your Dishwasher. After you remove the rust you will then want to apply a rust inhibitor to keep it from coming back. You can go to a website called http://www.rustremover.biz or http://www.nebraskanhotrod.com to learn more about Evapo-Rust. You will also find that they sell a water based rust inhibitor that will work to keep the rust from flashing back for up to 6-months.
Jenn Air makes great products, don't blame them. Your type of stainless steel is a consumer grade that has less nickel-chromium in the mix making it affordable to the consumer. The surface needs to be "pacified", DeBruce Polish will REMOVE THE RUST and PACIFY the surface. We get Debruce Polish at debrucepolish.com.
