Posted on Oct 28, 2009
One turn table goes louder than the other any ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
149
Points
If you are comparing the isignal using the same input, the problem is in the cartridge, it may have loose the ground connection or the cartridges are differents and each cartridge may have different output.
if you are using different inputs, one of them (the lowest) may be connected to the line input instead of the phono input.
: How can I keep my cat from scratching my kitchen table?
The best way to keep your cat from scratching the table isnot to spray in with an unsavory smelling product as many people suggest. This is a bad idea because you have to eatoff that table! I recommend consistentlyspraying your cat with water from a spray bottle every time he goes to sit onthe table. Eventually he will connectthe dots and see that sitting on the kitchen table is not allowed.
May 29, 2012 • Furniture
Oven not heating. runs but no heat. GE Spacemaker (11 years old) Light works, table turns. Seems a little louder when turned on
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Whirlpool gas dryer wont spin
timer relay is bad
Feb 24, 2010 • Dryers
1helpful
2answers
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Steaming problems
Have you tried descaling the machine?
Sanyo microwave model em-s5002w won't heat...sounds louder
Sounds like a component failure in the microwave circuit.
It will be one or more of the following -
Fuse
Diode
Capacitor
Transformer
Magnetron
Reply back and I can help you more. These failures happens to new or old microwaves.
My table saw will turn on, but sounds very loud
Possibly bearing wear, or the blade rubbing against the guard/housing. Unplug the saw and spin the blade slowly by hand, if it feels notchy then I would suggest bearing wear. if it only seems to feel notchy in places then it could also be damaged gears.
Oct 24, 2008 • Saws
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
