ASUS CROSSHAIR Motherboard Logo
Posted on Oct 28, 2009
Microsoft Solitaire Helpline Call 1-8O5-225-6690 We are 24 Hour Available Call Now
Is there a good diagnostics program for the Asus Crosshair motherboard that will tell me if the board is functioning correctly? I'm trying to figure out why my computer is stalling for several seconds when playing WMP 11 or even Microsoft's onboard solitaire game. It's like it just pauses and then will continue the function or playback after 10-30 seconds. It seems like it's got a chokepoint of some sort. I'm also suspecting the Seagate 250 gig hard drive or Windows Vista of slowing it down so I'm trying to narrow the possibles a little bit. I'm using an AMD 3.1 mhz processor with 6 gigs of OCZ memory.
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Oct 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
2898
Points
26
Google asus probe and install it to check your voltages and temps. also look at your task manager to see what your cpu and memory loads are. with that sort of setup, things should be running pretty good. my guess is your temp is high.
How do you COMPLETELY REMOVE Spider Solitaire from Windows 7?
Click on the Start button and select Control Panel. From the Control Panel window, click on Programs, and then click on Turn Windows features on or off. Click on the plus sign next to Games in the Windows feature list to list all installed games. Now click the check mark next to Spider Solitaire. Click OK now to remove Spider Solitaire for good.
How do I enable my HDMI out on my Asus Crosshair II Formula Motherboard?
HDMI and VGA are part of the video card not mobo. I don't see ASUS placing an integrated video card on such nice board.
Hi, Hope you can help. I've just fitted a new motherboard to my computer (ASUS crosshair 2 formula). My memory is 2 x 2GB DDR2 running at 800Mhz. Th machine will run fine using either of the sticks, but...
Hi. Asus has a great utility that lets you update your bios even in Windows.
http://www.asus.com/product.aspx?P_ID=EIDxaW1Ln3YR9RA2
At the download section select your OS and in Utility section find "ASUS Update V7.14.01 Install Program" This program will automatically update your bios.
As for your Ram issue. Did you try each stick in each ram slots ? If you did and saw no issues, then I am only suspescting of incompability between your Rams.
I'm unable to open any of the following games like Chess titans,Hearts,Mahjong Titans,Minesweeper,Solitaire,Spider Solitaire.Please help. Rajkishore Singh
go to START > CONTROL PANEL > ADD REMOVE PROGRAMS
then SELECT ADD/REMOVE WINDOWS COMPONENTS
then SELECT ACCESSORIES and DETAILS
then put a check / uncheck on GAMES, then press OK.
How do I get USA warranty support from Asus?
This is the direct link to the Asus RMA request form for USA & Canada.
http://vip.asus.com/eservice/usa_rmaserv.aspx
This is the link to the technical support request form.
http://vip.asus.com/eservice/techserv.aspx
Robert from Blitware
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
