Hi, this problem is caused by the cut off switch not depressing far enough to turn unit off. To remedy you need to do as follows. 1. Disconnect from power supply. 2. remove platter. 3. Flip unit over to expose the underside and remove all screws. 4. Remove base board. 5. Look at the gearing beneath the tonearm and identify switch that tonearm depresses at the rest point. 6. Loosen switch retaining screw and turn switch toward centre of turntable slightly until it clicks or closes. Tighten screw to hold switch firmly in place at that point.7. Reassemble and test.
go to a computer shop and buy a kingston solid state hard drive-250 gig for around $65.00 aud
next obtain a copy of win 7 with a registrable licence code and insert it in a cd drive
turn the computer on and hold down the delete key until the bios screen appears
move to boot tab
select cd as first boot device , yes and hit the esc key
turn off the computer then restart it
the bios direct will activate the cd and load the program into the hard drive and you are up and running
when finished , go back to switch off and do the bios start again and this time set the first boot back to hard drive
A 250 gig sshd is equal to 500 gig disc type and will not fail as there are no moving parts
Yes, but keep in mind the capacity or size of the memory card. Most video recordings require a large size of memory. I recommend get getting at least a 2 Gig card for video shots.
that is a dew sensor message /mean warm up your cam room temp press eject and get an air dryer
and blow hot air inside for a few seconds ,do not set the dryer at high level /medium or low to avoid damage to the plastic or inside it if that does nt work
you got to replace the sensor in the camera.....
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
