Maytag PAV2300 Top Load Washer Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just purchased a new top loading Matag washer to replace a 15 year old sears. The old one pumped to a dischard about 6' up from the floor without problem. Will this one do the same with a few feet of hose added? Will I need to put a check valve on it? It is not going to be delivered until Thursday so I have time to stop it if this will not work. Thanks - John #120620 MVWC6ESWW
  • jbramsey47 Oct 27, 2009
    I will let you know. Cheers! John
Anonymous
Level 3:
President:
  • Master 1,304 Answers
  • Posted on Oct 27, 2009
Anonymous
Master
Level 3:
President:
Answers
1304
Questions
0
Helped
367217
Points
3700
Hi john
this unit is rated for an 8' pump, a few years after it hit the market Maytag put out a high volume pump for discharges over 6 feet high
I know what your thinking ,,,,, dont forget the two feet inside the machine......
your darin is right at the rated height,
Since it is new I would assume it comes with the new high volume pump so you should be good to go
Anonymous
Level 3:
President:
  • Master 2,702 Answers
Anonymous
Master
Level 3:
President:
Answers
2702
Questions
Helped
909770
Points
7895
Il tell you this much,,, its a very long way up for it to pump water up, if it can, fitting a check velve would be a good idear, but dont hold you breth that it can pump water so high up
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
1874
Points
29
You WILL need a check valve inline about hafe way up
1helpful
1helpful
Haier top load washer: washes and drains but stops working at rinse cycle. Super capacity model but no model number I can find. The unit is about 6-7 years old.
Call Sears or GE service...either can address the problem. They may offer you a one-year contract, which is worth the price. If they can't fix it, you will get a credit toward the purchase of a new unit.
2answers
43142 Front Load Washer: Our Kenmore 41741042000 is 9 years old and is star...
Open up the washer, grab the metal basket and lift it up and down. If there is any play in it then buy a new washer. Replacing that spindle and bearing is not cheap. Spindle can only be purchased by also buying a new basket and that can cost $500.00 or more just in parts.
If this is what the inside drum does at all, then it is toast. Washer Spin Basket Part Number 131618500 Sears PartsDirect
This is the basket for your washer and it is $314
And if you decide to go that route then you will need the outer rear tub because the bearing is part of that tub and it is $246 Washer Outer Rear Tub Part Number 131462800 Sears PartsDirect You also have to ask yourself that since it is 9 years old, If I replace the tub and drum what else will go out? The motor? It's $120. What about the drain and re circulation pumps? Well it's $82. It will be cheaper on you to bite the bullet and purchase a new unit.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
My washer pours water onto the floor when it drains
If it's a top load, it's likely the pump is shot and needs to be replaced. If you feel like taking it on schematics are on line and the pump is relatively inexpensive compared to replacement of the washer. If you use a repair company, it might be cheaper to replace the unit, especially if your washer if more than 5 years old. Check if warranty is still available to purchase from SEARS, If it is, it be be a steal to buy extended warranty and have SEARS fix it.
22helpful
4answers
F35 and Suds error on Kenmore Elite HE5t
I also got the SUDS error followed by F35 many times. I replaced the analog water level switch, Wirlpool part number W10156252, and the problem went away. The part is located against the back right corner of the top of the washer after removing the top cover. The part cost $62.99 + $12.95 express shipping from ApplianceZone.net. I have the Kenmore HE3t Steam Washer, model number 110.46752 700 front loader. I was able to run about 6 loads of laundry by unplugging the washer, waiting about 5 minutes, the re-plugging and re-starting the washer. Thereafter, the problem became permanent. I always used HE detergent. The washer was purchased new in December 2007, and the I made the repair in September 2009. I spent about $1300 for the Kenmore H3t Steam Washer, and I am disappointed that it required repair after less than 2 years. My mothers old Maytag washer lasted more than 15 years, and was not susceptible to soap SUDS.
1helpful
Trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
3answers
Will not advance to the rinse and spin cycles...
The buzzing can only be that the pump if sticking or the inlet valve is sticking, other than that it is lack of water supply. Regards Advisor
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
