Sharp UX B700 Plain Paper Inkjet Fax Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can send faxes put not receive them...just keeps ringing
Anonymous
Level 3:
  • Master 541 Answers
  • Posted on Oct 27, 2009
Anonymous
Master
Level 3:
Answers
541
Questions
0
Helped
215189
Points
1334
You need to program you machiner to auto answer it is on manual answer and will only keep rining
Cant send fax
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
5helpful
2answers
I can send a fax, but can not retrieve. Line continues to ring,
Press the START button while it is ringing. Scroll through the menus and set your machine to AUTO RECEIVE.
Fax machine will not receive a fax
try switching the fax with a phone and calling... that phone with your cell... see if you have static... if you have static on the line... then call your phone company and have them fix the line... or try putting a magnet filter on the line... next reconnect your fax and call... if your phone line is ok... and it just keeps ringing.... adjust the ring wait time to 2.... if thats doesn't help... you have a bad mainboard...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Can send faxes, but no fax tome coming on when the number is called
that's right,you would be able to send fax,but wont be able to hear the fax tone,your fax ring shoud be 2 rings higher than answering machine,or else,do 1 thing when you hear the ring,just pick up the receiver u wud be able to hear the fax tone,do not disconnect the call,just keep the receiver aside without disconnecting,and then press start fax...you will be able to receive fax...........
1helpful
I can only receive faxes not send when i try to send it just keeps ringing will not transmit
If you dial a number and just hear ringing that means the other end is not answering. Even if a person or answering machine picked up the ringing would stop. The problem is at the other end.
2answers
LEXMARK X5495 New printer, can't send receive faxes
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines
1helpful
2answers
Cannot receive faxes, but can send
I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
3answers
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
2answers
Cannot recieve faxes
you need to watch during ringing period need to click ok or press what ever message says.
Able to send fax cannot receive fax
make sure phone line is pluged into line on fax,make sure fax is set auto.there should be a button on fax panel that say's receive mode.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
