2004 GMC Envoy Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brake lights wont work right tail light wont work 2003 gmc envoy
Anonymous
Level 2:
  • Expert 507 Answers
  • Posted on Oct 28, 2009
Anonymous
Expert
Level 2:
Answers
507
Questions
0
Helped
187170
Points
957
Check globes and check brake light switch under dash on brake pedal.
1helpful
3answers
2003 GMC envoy XL...tail lights work but brake lights will not work is it the brake light switch and how can I test it
ST/LP, Fuse 12, 25 Amp - feeds battery positive to brake switch ORN (orange) and out the WHT (white).
Test with a simple automotive incandescent test lamp to ground. Test lamp should light on both sides of the fuse and with contact to the switch ORN and to WHT while brake depressed.
1helpful
Where is the tail light fuse?
The tail light fuse is under the rear seat on the drivers side.
I have a 2005 GMC Envoy. Have tail lites but no brake lites. Third lite on top works whet brakes applied
Since the high mounted brake light works you know that the brake light switch is working. Now you need to check the brake light bulbs in the rear tail light assemblies. The brake lights are separate from the tail light (parking or running lights). There are two screws that hold the rear light assemblies in place.
1helpful
2003 GMC Envoy have no brake lights, only the top light on the gate works, can you help thanks
First and easiest we need to check for power going to the rear lights at the plug that goes into the tail light housing. There is a board that the lights plug into that goes bad. The Envoy uses separate brake and turn bulbs so the 3rd brake and the two side are on the same circuit.
A few minutes after I turn the engine off on my 2003 envoy one of my tail lights comes on and stays on. what should I check? thanks
Which of the tail lights comes on? Is it the parking light or brake light? And is it only one side that is coming on? This is a very strange symptom. The Body Control Module (BCM) controls the light and could be the problem, but before replacing it, a good diagnosis needs to be done.
The break lights don't work
brake light switch or bad groung at the lights
2003 gmc envoy xl brake lights dont work
theres usually a pressure switch behind the brake pedal, sometimes the plastic hex nut rattles loose and you have to retighten it.
4helpful
2answers
sounds like a fuse look under the dash panel for fuse cover look at the back of cover and check that fuseThanks for using fix ya Please rate my response thank you very much
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
