Master
- Posted on Oct 27, 2009
Re: NEED TO KNOW HOW TO PROGRAM REMOTE; WHAT BUTTON TO...
There are different methods for different remotes and the follwing are the basics. First you will have to put the remote into the mode for the appliance you want to program (TV, DVD player, Receiver, etc.) There should be a slider switch or a button that corresponds to each device. For example if you are attempting to program the remote for a TV do the following.
Step 1
Turn on the TV.
Step 2
Open the battery panel of your remote and find the model number if applicable.
Step 3
Find the codes for your remote model and the brand of TV you are using by going to the list provided with the remote.
Step 4
Press and hold the TV button on the remote. Because you are holding down this key, the ON/OFF key should stay on.
Step 5
While still holding down that button, hold down the ON/OFF button. The ON/OFF button should turn off and back on.
Step 6
Let go of both buttons. The ON/OFF button should be lit.
Step 7
Enter the four digits code (or codes) you obtained in step 3. The ON/OFF key should blink once.
Step 8
Press
the ON/OFF button. If the TV doesn’t turn off, wait 4 seconds and press
it again. Repeat this process every 4 seconds until the TV turns off.
Step 9
Once the TV turns off, you must press STOP in order to save the codes.
Step 10
Try to use the remote control functions, it should work now.
Repeat the process for each device you want to program into the remote. I hope this helps.
