With all the new EPA guidlines on emissions there are many new type of carbs.The older type was easy, If its a walbro or zama brand and it has 2 adjustment screws as well as an Idle speed, preset the low and high at 1.25 turns out from set, start the saw, run it to full throttle,adjust the high speed needle counter clockwise untill you hear the engine start to flutter. You want to year the flutter about once every 4 seconds.then let it idle,adjust the low speen till it runs smooth then make it 1/8 turn richer. Many of the new carbs require special tools to adjust, not brain surgery, just to keep the air cleaner..
SOURCE: need initial carb adjustments for both high and low adj.
start at 1turn out on both that should grt it running from there..
SOURCE: homelite chainsaw carb adjustments
I'd replace the fuel pickup and line. It sounds like you are getting air into the fuel system ahead of the carb.
SOURCE: 2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
SOURCE: adjust high low screws on carb.
I just finished looking at mine and I think they made it that way so back yard mechanics dont tinker with it. If there is a Poulan dealership in yout area that would be the place to get it.
SOURCE: high & low carb needle settings
I would start with both the "H" and "L" needle valves at 1.5 turns CCW from lightly seated then adjust for performance as follows:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Testimonial: "thanks guys&gals i used to work on all this stuff as you get older you tend to lasp onse in awhile. thanks alot mack"
