The inner element (6'') does not work while the outer (9'') works. When I turn on the 6'' element it does not work. When I turn on the 9'' element only the halo (outer part) of the 9'' works but the center 6'' does not turn on. Any one knows what's wrong?
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
You are describing a dual element, inner & outer. you likely have a break in the inner part of the element and it will need to be replaced.
The left rear power plus burner does not have a very good flame
