Palm Treo 500 Centro Logo
Posted on Oct 26, 2009
Phone sceen turns on. fully charged. touch screen works. Phone doesn't turn on. Phone off displays after I have touched the on/off switch.
Dale Jones
Level 1:
  • Contributor 21 Answers
  • Posted on Oct 30, 2009
Dale Jones
Contributor
Level 1:
Answers
21
Questions
0
Helped
10870
Points
60
With the phone screen showing, press the red button at the right-hand side and hold it for about two seconds. The Centro should display a "Welcome" screen, then after a few seconds the phone screen should reappear with the carrier name at the upper left instead of "Phone Off". Each time you press and hold the red button the phone switch on/off..
Touch screen for definition only works when I turn on the ereader and after that when I touch the screen for definition it doesn't work. It turns the page instead.
Hi Darnellakell!
I´m not sure if you already tried to reset the reader, turn it off, and hit the reset button at the bottom of the reader then turn it on. Just make sure the reader is fully charge, your books will not be affected =)
You can check this forum and ask your questions too =)
http://digialreader.freeforums.org/prs600-f8.html
I droped my lg virgin rumor touch and The touch screen cracked but when I turn it on it stays black. What could I do?
If you won't see anything on screen,check if the phone is booting or turning on,if it turns on,display is probably the problem.but if doesn't power?software problem is the main cause.and with this,need to replace LCD as well as touch screen that was damage too.
If your mobile has a warranty,you can bring it to the service center for spare parts replacement.If you try to open it and it's under warranty,this will void you warranty and unable to benefit free of service charge.
9helpful
2answers
When i power on my lg vx11000 all that displays on the screen is (battery required) and the thing is the battery is fully charged and indeed attached to the phone correctly?? plz help
try to turn it off, remove the battery, then press the power switch for about 10 seconds. After that, connect the battery making sure the contacts are okay, then switch on the phone again and see how it goes. hope this helps and your rating/comment would be appreciated.
2answers
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Accidentally dropped HTC diamond - Display blackout
zohail, i have similar prblem and would liek to give it a go myself. could you provode further instruction?
Thanks in advance
Alex
2helpful
3answers
Htc touch, touch screen not working
The touchscreen is a thinlike mylar sheet that overlays the screen. Once damaged, all you can do it get it replaced. To verify if the touchscreen is "smashed", try using the thumbwheel or up and down buttons. If you can move around the display, then this means the touchscreen is damaged but will not prevent you from using your device, that is, until you turn it in for repair/replacement.
3helpful
2answers
Lcd touch sceen needs resetting it is misalinged
you get to the touch sceen by holdin down the frist tow buttons and turning the machine on the singer sceen will turn on just touch the sceen and you will see a small black box touch the box and it should move touch it four times and then touch the stright stiche white button at the bottum of the sceen it will save the settings and it will work .
2helpful
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
