I purchased a use EnGeniue SN-920 Ultra Cordless with Two handsets. I did a register test seperstely with each handset and they work OK. When I try to register both handset to the base, the first handset connects and registers OK. When I try to register the second handset I get an error that states 'no connections'. The user manuel dose not have a trouble shooting section.
Open for assistance.
Thanks
This is the registration procedure
Step 1: press MENU-6 and select 3 “SET BASE”
Step 2: press the REG key on the master base
Step3: press register to finish the registration procedure.
• After the registration complete, handset 11 and handset 21 can
2-WAY intercom with each other
If issue persists reset the unit start registration by using 2nd unit that currently unable to register. if issue continues please inform for further troubleshooting
Good Luck
Both handset will register individually but when I attempt to add the second handset to the base, handset #2 will not connect, even when I repeat the procedures over and over
Thanks......Waiting for more tips
