Heating & Cooling Logo
Posted on Oct 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dyno-Glo propane heater Model RMC-FA100DLX. It will light, the blower works, but will not heat up. you can almost hold your hand at the front while it is on. It is as though it remaines in the pilot mode. [email protected]
Anonymous
Level 2:
Sergeant:
  • Expert 232 Answers
  • Posted on Oct 26, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
232
Questions
0
Helped
121216
Points
598
Find the thermostat and jumper out the two wires if it shifts into high heat, replace the thermostat.
2answers
My Dyna-glo model RMC-8001SS propane heater will spark but pilot will not light. It's been sitting in storage for a few years. Any ideas? Thanks!
Possibly a failed thermocouple? Is there a button you have to hold in after it lights. If there is, users often let go to soon. First you have to pull the gas through the system. Can you hear the gas hissing?
https://www.mrheater.com/catalogsearch/result/?q=+RMC-8001ss+replacement+thermocoupler+parts
or you could ask them
Please call our Service Department at 1-800-251-0001, where our technicians will gladly assist you.
To order Service Parts in Canada, you may use the schematic tool to find the correct item numbers but must call LionCove at 877-477-3353 or go to Lion Cove Parts to place your order.
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Ihave a dyno glo heater rmc-lc20ngt nateral gas can it be converted to propane
You didn't specify whether it's a vented or vent-free heater. I suspect it's Vent-free. In which case NO!
Doing so would override any of the safety features that are built-in to shut it down if something goes wrong.
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
1helpful
I have a dyno glo rmc-fa100dlx forced air heater. It will light and work for a few minutes, up to about 5, then it will stop heating and the fan will keep blowing. any ideas? thanks!
If the unit comes on and runs but then shuts down, that sounds like an indication of a high limit trip.
Most, if not all, furnaces have high limit switches that keep a constant check on the temp inside the furnace or air handler. On most systems, once this high limit switch has been made (got to hot), the limit switch breaks control voltage to the heating device (strips, gas, fuel, etc.etc..). The blower motor continues to run until the high limit has dropped in temp and reset itself.
On some models, the high limit is a manual reset, meaning you need to reset the switch yourself or shut the unit off and then back on to reset it.
Check all filters and replace as necessary. Check the coils and fan blades for dirt build-up and cleanliness. Check motor belt (if applicable). If all these fail to solve the problem, then your issue either lies within the blower motor itself not moving enough air for proper heat transfer. Or the high limit switch itself is failing.
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
4helpful
2answers
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
john h
Jay Finke
Jay Finke
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
