Problem:- User's modem does not dial or does not connect. Tip:- Prove that computer is connected with phone line and check that phone line contains dial tone.Therefor check that connection is connect or not.
Connection may not be less than six feet (1.8 meter).
Check dial tone by plug in the phone in phone jack.
If user has many more services (such as call waiting,call messaging OR voice mail) then check that these all are cleared or not and check call waiting is disabled while using modem.
Disconnect any answering machine,fax machine or printer which are on line with modem.
Check that are you not using digital,rollover or PBX line?These type of lines not works with modem.
Try with another phone line. (For this, you have another phone number or another phone line).If user connected with another line then you need to complain in phone company.
Check the LED lights that are blinking on the front of the DSL modem.
Check the "Internet/Online" LED and make sure it is blinking green or a
solid green. If this LED is not blinking, then the modem is not getting a
phone signal, or the service is out. Remove the line and check it to
make sure that you're getting a signal. Check to see if filters are connected to the phone lines that are all
around the house. These filters separate the phone line from the DSL
line so that the lines do not crosswire and disturb the Internet
connection or the phone connection. The DSL is usually shipped with a
couple of phone filters. These phone filters can be purchased at many
electronics stores or provided free from your Internet Service Provider.Check to see if the modem is connected to a wireless router. If the
modem is connected to the router, try disconnecting the router and
connect the modem straight to a computer. If the modem is also a
multi-port wireless router, then connect the computer to a different
port on that same router.Reset the router if the previous steps do not resolve the problem.
Follow the initial set up instructions given to you when you first
installed the router. Perform any firmware updates that might be needed
once online, and use the discs that came with the modem.
692 - Hardware failure in port or attached device. This behavior can occur if any of the following conditions exists:
The modem is turned off or malfunctioning.
If you have an external modem, the serial cable is incorrectly wired.
If you have an external modem, the serial cable is not securely connected or has open connections.
The serial port or multiport adapter on the RAS server or client is
malfunctioning.
The handshaking options for the modem are incorrectly configured.
The modem is unsupported, or the chosen emulation may be incorrect.
The modem .inf files become corrupted or the modem driver becomes corrupte
To solve this problem, use the appropriate method:
Reset your modem. Consult the documentation for information about how to reset the modem.
If you have an external modem, make sure that you are using the
correct serial cable. For more information about requirements for
proper
cabling, refer to the "Cabling Requirements" section in Dial-Up
Networking Help.
If you have an external modem, make sure that the serial cable is
connected securely.
If you are using a pin adapter to connect your external modem to your
serial port, make sure that the pin adapter is wired properly for modem
communication. For example, a 9- to 25-pin adapter for a mouse does not
work properly with an RAS serial setup.
Test the serial port or multiport adapter, and replace the adapter if necessary.
Make sure that the handshaking options for the modem are configured
properly. Consult the documentation for information about the
different handshaking options that are available for your modem.
Contact the modem manufacturer to see if any setup and
initialization information is available for your modem. Also, check the
latest Windows hardware compatibility list (HCL) to make sure that your
modem is supported.
Use Device Manager to remove the modem. You
can do this in safe mode or in normal mode. Restart the computer in
normal mode. Windows will redetect the modem and reinstall the
correct drivers.
Hi to resolve this problem, use the appropriate method:
If you have an external modem, make sure that you are using the correct serial cable. For more information about requirements for proper cabling, refer to the "Cabling Requirements" section in Dial-Up Networking Help.
If you have an external modem, make sure that the serial cable is connected securely.
If you are using a pin adapter to connect your external modem to your serial port, make sure that the pin adapter is wired properly for modem communication. For example, a 9- to 25-pin adapter for a mouse does not work properly with an RAS serial setup.
Make sure that the handshaking options for the modem are configured properly. Consult the documentation for information about the different handshaking options that are available for your modem.
Contact the modem manufacturer to see if any setup and initialization information is available for your modem. Also, check the latest Windows hardware compatibility list (HCL) to make sure that your modem is supported.
Use Device Manager to remove the modem. You can do this in safe mode or in normal mode. Restart the computer in normal mode. Windows XP will redetect the modem and reinstall the correct drivers.
I would contact my ISP, the problem could be in the line somewhere. If there was a storm that went through lightning could of hit a phone line, or circuit, between you and the co.
the problem is with your modem....did you tested the local loop from router to modem....are u getting local loop from one modem till router or not...try first checking local loop from modem to router...
