Google for remove bios paswoord
Resetting the BIOS Password using Software
Every system must store the BIOS password information somewhere. If
you are able to access the machine after it has been booted
successfully, you may be able to view the BIOS password. You must know
the memory address where the BIOS password is stored, and the format in
which the BIOS password is stored. Or, you must have a program that
knows these things.
You can write your own program to read the BIOS password from the
CMOS memory on a PC by writing the address of the byte of CMOS memory
that you wish to read in port 0x370, and then reading the contents of
port 0x371.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
If it is desktop, find a block of 7/8 switches, move switch 6 to the opposite direction and plug the power into the computer. DO NOT TURN ON, leave for 5 minutes, reset switch 6 back to the default posistion and reboot. dont know for laptops, but see if the bios battery is under the main battery.
You maybe able to reset the BIOS to the factory default by removing the BIOS battery and wait for 20 mins before inserting the battery again.
The BIOS will return to the default setting, you then need to go into the BIOS configuration to set the Time & Date.
