1. I have error code 07 on my Krups XP 7220 coffee machine. What does it mean?
2. Why is the list of the error codes a secret? Why can't I find the list on the home-page of the Krups?
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
My Krups Automatic Espresso machine was just repaired for another problem, and when we gave it a test run- ERROR CODE 07!
We called the repair place and they weren't surprised or upset. Apparently it just means something with the water intake. Make sure that you put the water tank on correctly. Leave it off for a few minutes, and then try it again.
This worked for us! Hope it helps you.
We have just fixed this error in a Krups 7225 this error means the tube where the ground coffee comes out of is clogged up. Remove the top of the machine, hopper that holds the coffee and the bit underneath, you will need a Torx screw driver for this. Clean the clog with a tooth pick or something else sharp, blow air using a air duster can we also used a paint brush (new) to clean out all the coffee grinds. While you are there you can vacum all the old grind out as well.Coffee maker works once again.
blah! Error code 7 means, that I had to change the filter.
