Wire its not coming out when i push the buttom i only hear a click like a relay on the circuit board i check the wire feed motor and its good i applied 12v and spins with no problems also i check the reset buttom and its good , any help please
You do not indicate if the wire is already out of the nozzle. If not, commonly the wire can jab the side of the tube it runs through and cannot advance.
IF the wire is already threaded, then there MAY be a fuse to protect the motor.
The click MAY be the gas valve, or the relay driving the motor and/or the main transformer for welding current. The circuitry for these is relatively simple and a voltmeter is your friend to troubleshoot this.
Sounds simple, but have you checked the spool to ensure that the wire has not crossed over itself. Don't ask me how I know to check this.
Semper fi
Grit
Open the cover while you depress the feed trigger and verify if the wire is in the feed-wheel groove and that it's not slipping, that you have good contact and adequate driveroll pressure. It's most likely the switch in the gun trigger, a common failure and cheap to fix to.
Did you purge the gas
